Old 03-28-2015, 10:31 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Ford vs Chevy Build-up
The 2 sets of Hedman headers I have had on my car, the steering shaft has to be removed. I also run the exact same engine mounts.
The steering shaft should not be that big of a deal to remove and reinstall. Your getting really close to having it running!
Sean Marconette
84 Mustang
5060 SS/N
Old 03-28-2015, 10:45 PM   #2
Rich, I kinda skimmed back through and didn't see much detail on the engine, unless I missed it.
What did you do for pistons? Ring combo? Cylinder heads? Camshaft?
Thanks
Old 03-28-2015, 10:58 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Brian is trying to send me a link to the Flowtech headers he uses...individual tubes like the Kooks.
Mark - I used a CompCam Stocker grind 246/252 @108. Cheap approved SpeedPro pistons with an oddball TotalSeal ring package. Heads were refreshed with new valves, beehive springs and pedestal mount roller rockers. Did the best I could with oil control.
Rich Taylor
I/SA - 321
Old 03-28-2015, 11:24 PM   #4
west coast
Liked 230 Times in 75 Posts
I second looking at those motor mounts what brand are they? not to many people make solid mounts for the foxbodys and some have the engine in a different location then stock. I believe the rule book says engine placement in the stock location. my headers are kinda touch if the motor is not level in the car, big slots in the subframe for the motor mounts. I use pacesetter on my car under $300 for them, my merge collectors are more money then the headers.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 03-28-2015, 11:30 PM   #5
HandOverFist
Problem solved... http://www.summitracing.com/parts/bi.../model/mustang Slip-fit tubes will make my life easier...all I need do is cut the flanges. I don't recall the brand of solid mounts, but yes the engine is still in the factory location front/back - up/down.
I'm not inclined to mess with that shaft again...it was a pain when I put the manual rack in.
Rich Taylor
I/SA - 321
Old 03-29-2015, 12:37 AM   #6
Rory McNeil
Liked 1,112 Times in 304 Posts
Those 1 piece solid motor mounts look the same as the ones on my Mustang. I don`t recall the brand, but I bought mine from Alex Denysenko at Moneymaker Racing. I also have the long tube FlowTech headers, the last tube on the drivers side has a slip joint, and runs over the top of the steering shaft. (the other 3 tubes fit between the steering shaft and the engine). They fit well, at least with a stickshift.
NHRA 6390 STK
M/S 85 Mustang
Rory McNeil is online now   Reply With Quote
Old 03-29-2015, 01:23 AM   #7
HandOverFist
Yeah, Brian filled me in on them. The right side has two slip joints and the left has three. He has a manual rack and a large bellhousing so I should have no problem.
Rich Taylor
I/SA - 321
