Old 04-13-2015, 09:43 AM   #1
Alan Nyhus
Liked 800 Times in 237 Posts
Default Re: '67 Camaro E/SA redo
I see we have similar thoughts, with different approaches, on crankcase pressure.......
"That'll never work....."
Old 04-13-2015, 01:11 PM   #2
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Rich, Can you post info on the header extensions that you had on here earlier. I thought you had a picture of some, but I don't see it. thanks
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 04-18-2015, 08:07 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Alan - I looked into your idea, but it just did'nt seem any more flex proof than what I already had. Going to try this mount tm along with a 5-1/2" crank pulley...hoping the alternator will clear the crossmember below.
Rich Taylor
I/SA - 321
Old 04-19-2015, 09:24 AM   #4
Alan Nyhus
Haven't had any excessive flex issues, Rich. The crank pulley is about 3" and the belt isn't tensioned real tight, though. That bracket you have looks to be a nice setup. -Al
Old 04-19-2015, 06:58 PM   #5
HandOverFist
Still a problem in that the new bracket will not work as expected. Guess I'm going to have to whittle one out myself.
Rich Taylor
I/SA - 321
Old 04-21-2015, 03:04 AM   #6
HandOverFist
Weather permitting I'm taking it to the track this Friday evening to test the transmission repair and if the engine will perform. Perry is working on a solution for the alternator bracket atm, but it will go with or without it...I need to know if there are any problems that need attention now, not two days before the next Combo race.
Rich Taylor
I/SA - 321
Old 04-21-2015, 09:13 AM   #7
Alan Nyhus
Rich, I've used this alternator mount from Speedway before in early Camaro/Nova subframes using the standard Delcotron alternators:
http://www.speedwaymotors.com/Small-...ain,35790.html
It clears with the 'short' crank pulley and can also be spaced forward to work the 'long' crank pulley. Fits the Camaro/Nova subframes very nicely. -Al
