Old 04-21-2015, 02:50 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 282 Times in 78 Posts
Default Trailer Tire Balancing
I am getting ready to replace the tires on my trailer, and after pulling all 6, I found none are balanced not even the spare? Here's the scary part, these are the original tires for the trailer. They are date coded late 2005.
Is this common for factory trailer tires to not be balanced? These are on aluminum wheels. I guess having the trailer inside, out of the weather and sun has made a difference on tire life since I have owned it. I am the 3rd owner and the previous owners did not travel far with it.
The trailer is a 2006 48' LQ Classic Dominator.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 04-21-2015, 07:14 PM   #2
tj310
Default Re: Trailer Tire Balancing
Quality tires shouldn't need balance , if you check them and they'r not out more than 3 oz should be good, on a trailer ---Trevor
Old 04-21-2015, 10:40 PM   #3
Run to Rund
Liked 56 Times in 29 Posts
Since no one rides in the trailer, and your poor car can't tell you about the rough ride, many companies don't spend the time and money balancing the tires. I always have the tires balanced.
Old 04-22-2015, 10:39 AM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
With no shocks on the trailer wheels to control any imbalance the tires will show excessive wear and beat up everything inside.........
Quality tires or not, have you ever put 4 tires on a spin balancer and not have to add weight?????????????
It seems that balance is the last item needed to complete the job and protect your investment....
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-22-2015, 10:53 AM   #5
Fireofficer5
Liked 33 Times in 20 Posts
When I was a tire monkey in 1977, every truck tire and trailer tire was balanced.
There were four and eight ounce weights.
Fireofficer5 is offline   Reply With Quote
Old 04-22-2015, 02:17 PM   #6
Sean Marconette
I thought it was very odd to find this too! After searching the internet on trailer tires it is not an uncommon practice from new manufacturers.
So buyer beware! The time and money for whats riding in the trailer bouncing down the road is too important. Everything being beat to death is not worth it.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-22-2015, 05:48 PM   #7
MR DERBY CITY
Liked 8,260 Times in 1,543 Posts
What Bob Mulry said.....M.J.
Old 04-24-2015, 11:34 PM   #8
tj310
Sorry I was forgetting not everyone has an electronic balancer at home . I just put 4 new 16" tires on my trailer 3 came up at 1 oz or less and got no weights one got about 3oz. If you jack your trailer up and let gravity find the wheels heavy spot you can add weights to the top which will be the light spot. ---Trevor
Old 04-26-2015, 03:24 PM   #9
Dick Butler
Liked 32 Times in 19 Posts
You probably did even better since you balanced the drums with the tire/wheel combination.
