#391 |
Liked 227 Times in 74 Posts
Rich looks like you created some of your own problems should be easy to fix with some time. I believe you o2 sensors are daisy chained together in the wiring so if one is not plugged in the other one will not work. Some of the years of cars are wired differently on this circuit. if you are missing the engine coolant sensor you will have problems, your after start enrichment table is like a choke will not change your fuel going to the motor as it warms up. Have not used the system you are working with just the stock computer with a chip. hope this helps. good luck
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#392 | |
Liked 19 Times in 12 Posts
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
#393 |
Liked 61 Times in 25 Posts
Put the ECT sensor in the intake where the heater tube came out of. The o2 sensors are not causing the current issue by themselves, but will cause tons of other tuning issues.
So, Reroute fuel Add ECT sensor Add o2 sensor Should correct the issues, possibly have to lower fuel pressure a little, but maybe not, every engine is different. Last edited by Tony Corley; 04-30-2015 at 11:09 AM. |
#394 |
You need both hooked up for the factory EEC. Not sure on the aftermarket setups.
#395 |
Liked 33 Times in 16 Posts
Ok guys - I will re-plumb the fuel system to mimic the second diagram, add the coolant sensor and install the other factory O2 sensor. If that corrects the current problem I'll add another bung for the wideband sensor. I will try to make some screenshots of the controller readings.
Rich Taylor I/SA - 321 |
#396 |
Liked 79 Times in 11 Posts
with the pms , you can tune and run it without 02s. I haven't had them in my car for 4-5 years.
bob beals 7244 |
#397 |
Somehow I got it starting/running smoothly atm. Extended the harness for the temp sensor and installed it directly in the lower intake. I can see it registering in the PMS controller now. Both factory O2 sensors installed, but I have yet to see any readings on the PMS screen. Not sure if the MAP sensor is functioning. I don't know how to tell if the IAC is fuctioning or not. 12 degrees locked in with the spout connector out, then plugged back in.
I'll have to order a fitting for the fuel rail before re-plumbing the system. Idles around 1350rpm and does not stall when shifted into gear. I will need to get a weld-on bung fitting so I can re-install the wideband O2. While waiting for fittings I need to figure out why the new alternator has no output. ![]() ![]()
#398 |
Liked 240 Times in 112 Posts
While I'm not familiar with the screen output on that scanner, seen plenty others. Is that the IAT reading -30' ? Is it hooked up yet ? The first pic shows the engine @ 980RPM (i think), A heated O2 sensor (3 or 4 wire) should be showing voltage fairly quickly. 170' is more than enough time. Will that PMS let you lock out different inputs ?
Dave Noll, EF/S ,?/SA 6526 |
#399 |
Liked 160 Times in 51 Posts
Yep,
I agree with Dave...Looks like Intake Air Temp is way off at -30 .....that will make it way rich. Usually default is -40 when they are unhooked but check for the open plug. IAT sensor looks like your coolant sensor except the end is not sealed with brass, it has a thermistor exposed to get air temp. Should be screwed into #5 intake port or you can move it into the intake upper plenum by using one of the plugs located on the underside of the intake. O2s are not used in the base calculations for fuel..they are more like trimmers when the system is warm and in closed loop so they are not players on initial starts. I'm curious about the -29HG ..is that the.baro reading? Usually that is just expressed as a positive # Basics to get it running TP, ECT, IAT, BARO, Fuel Pressure, base timing. Looks like you are getting closer!
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
#400 |
Liked 204 Times in 54 Posts
Do the one-wire mod to the alternator. It's cheap to do, more reliable and safer. You will be able to diagnose any alternator problem very quickly.
