#1 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
Never have seen an OE brace on a Fox body, possible on a Cobra. PartsBob could verify that.....................
Are you running mufflers or an X pipe? Either or both would be a cheap increase in bottom torque for you, something those motors have very little of. |
Liked 335 Times in 182 Posts
nothing I can find in the NHRA rule book mentions shock strut braces either way---- only thing mentioned is that the suspension must remain OEM this has nothing to do with suspension it is a "body strengthening support"!!!--- check with NHRA get a definite ruling -- it is not a performance enhancing modification it is a safety or steering issue you are dealing with here--- If it were me I'd put one one show up at the track and if they did not like it pull it off otherwise plead your case and run the damn thing FED 387
#4 | |
Liked 204 Times in 54 Posts
If I had one on hand I would put it on to see what the difference is. I'm sure it will be fine for tomorrow. Thinking I will just let Kenny run it in the Combo if he wants to...I'll make fuel adjustments as needed. I have my high-tech data recorder on charge...going to mount the Go-Pro on the crossbar and point it at the afr gauge hehe.
#6 | |
If you can tig and have a bender, you could just make a cross bar out of chromoly and be done with it. It'll cost you $15 in materials and about an hour to make. . Have fun today. It should run good. |
