Old 05-11-2015, 08:44 AM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Woodfin's SS GT/TB construction series
If you go to an old time hardware store, you can find all kinds of springs for sale and often a mfr source you can contact if you do not find what you want. I have a selection of different pressure-rate-length springs that I have used depending on conditions. As a rule, the springs provided in the various kits or sources in the hot rod industry are too weak.
Old 05-11-2015, 09:39 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Dwight, Thanks, good tip.
Larry Woodfin 471W
Old 05-11-2015, 04:11 PM   #3
Darrin Christen
Darrin Christen's Avatar
Using just and inner spring works well also. Enjoying following your build. Thanks for taking the time to share.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 05-11-2015, 04:46 PM   #4
Mike Pearson
Mike Pearson's Avatar
Liked 1,958 Times in 593 Posts
I usually check mine without the head gasket then add back in what ever gasket thickness I am using. That way you know the head is sitting flat on the deck. I have made it a habit to check all 8 holes on an initial build too.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-11-2015, 08:39 PM   #5
Dragsinger
Darrin,
It is fun to post and update and I enjoy hearing the positive comments.
Larry Woodfin 471W
