Old 05-15-2015, 07:41 PM   #321
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
Q - What is happening with photos # 116 and #117?
A - Out with the mock up/construction block and in with the Super Engine!
ID:	28505   Click image for larger version
ID:	28506   Click image for larger version
Larry Woodfin 471W
Old 05-15-2015, 07:44 PM   #322
Dragsinger
Keep a close eye on the progress. The logo will go on at any time the movement comes on me.
These photos are teasers with the cover sheet still on. The second logo goes in the bad cover
ID:	28508   Click image for larger version
Larry Woodfin 471W
Old 05-16-2015, 10:18 AM   #323
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I approve of this logo
When I get the graphics stage, I'm going to have Michael do the work for my Mustang, "Optimist Prime".
Dale
Dale Shearon
68 Mustang 6394
Old 05-16-2015, 02:35 PM   #324
Dragsinger
Dale,
Michael is a good idea and design person, PLUS, a racer and promoter He has done several projects for me.
Larry Woodfin 471W
Old 05-20-2015, 01:59 PM   #325
Mike Pearson
Mike Pearson's Avatar
Liked 1,944 Times in 585 Posts
Build looks great. Looking at the picture of the engine bay I see the brake lines from the master cylinder running near the bracket for the midplate. I think the brake lines need to be on the outside of the frame rail or run through a steel tube in the bell housing area. I would check the rule on that.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 05-21-2015, 09:01 AM   #326
Dragsinger
Mike, good eye and good catch. I agree it needs some protection and will do.
Larry Woodfin 471W
Old 05-21-2015, 10:54 PM   #327
Todd Geisler
Liked 345 Times in 149 Posts
A few updates. Work is coming along steady these days. The last 2 - 3 weeks I have worked on a number of small items that take time, are important, yet do not show much progress like the big items do. When working the small stuff it is important to remember that ALL systems, ALL items are important.
First photo shows rear of bed items roughed in and the beginning of wiring runs. At the far right notice a ground terminal strip. A handy item to ground all components in the rear section. The strip is connect directly to battery negative with a 10 gauge lead. All rear component grounds branch out from there.
Second photo shows front motor plate bracket
Third photo is mid plate tab.
Larry, how do you intend to pull the engine when the motor plate is trapped by the forward cage bars?
Looks like with that odd setup you'll be forced to remove the motorplate from the engine to remove & install the engine.
Would be more user friendly to have the motor plate be narrower than the forward engine bars so the engine could be lifted out with the motor plate and accessories still bolted to the engine.
Todd Geisler is offline   Reply With Quote
Old 05-22-2015, 10:00 PM   #328
Dragsinger
It is Super 10 engine Friday
ID:	28611   Click image for larger version
ID:	28612   Click image for larger version
ID:	28614   Click image for larger version
ID:	28615   Click image for larger version
Larry Woodfin 471W
Old 05-23-2015, 11:22 PM   #329
Dragsinger
"Super 10"
Larry Woodfin 471W
Old 05-23-2015, 11:28 PM   #330
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
AWESOME !!!
Go Larry Go !
