Liked 2 Times in 1 Post
Charlie: Have you checked the roof ac to make sure it is ok - I would fire the Gennie and try your Microwave and hot water heater to see what the Gennie does - if it act's the same you probably have a Generator issue and I would start with the furl filter and invest in a small RV amp gauge that plugs into the recepticle so you can monitor Voltage
