Old 06-13-2015, 09:06 PM   #11
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Originally Posted by stocker396 View Post
Okay Dave as a Person who has Been There Done that WITH a Stocker with suspension You DO NOT Need to cut outer Body. The Front INNER wheel house MUST BE TRIMMED or it will chew it up on launch and leave. Also Roll the inner Rear to be safe because it can rub. 30 X9 Hoosier Radials and tested with 96" M/T too as well as 29.5 x9 M/T Bias. I have already covered ALL the options you are mulling over. You will like that bar Too.
Thanks for the info. I'll look at the front inside again, it makes sense it would be tight there. And I was definitely going to buy myself some clearance on the rear inside corner.
Dave Muller is offline   Reply With Quote
