Old 06-17-2015, 07:47 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Woodfin's SS GT/TB construction series
in photo #183 notice the starter bump button
and two more photos of the mostly finished engine
ID:	29310   Click image for larger version
ID:	29309   Click image for larger version
Larry Woodfin 471W
Old 06-18-2015, 08:00 AM   #2
Dragsinger
Ken,
I think your math is close. I had also estimated 8300 - 8400 engine finish line RPM. Gary Hettler suggested 8200 shift point so it's all fitting about right.
A few recorded runs with the Race Pac will tell the real story
Larry Woodfin 471W
Old 06-18-2015, 02:50 PM   #3
Bimbo Jones
Larry during time trials at a Motorplex's bracket race they have the 1/4 mile clocks turned on. Several racers take advantage of that opportunity to make a few 1/4 mile passes before we start the 1/8th mile race.
Bimbo Jones is offline   Reply With Quote
Old 06-18-2015, 04:59 PM   #4
Geerhead55
Liked 5 Times in 5 Posts
Talking Re: Woodfin's SS GT/TB construction series
Larry,, that starter bump button looks like you could dial in some delay to it if you wanted to! The motor is looking good.
Danny Durham
Old 06-18-2015, 06:19 PM   #5
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Larry,
Do you have a similar button to bump the fuel pump for fuel check? Just a suggestion.
Thanks for sharing your build.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-18-2015, 07:13 PM   #6
Dragsinger
Sean, good suggestion, the wiring is still working so it will be easy to add that. Thanks, good catch.
A button mounted on the motor place right there by the valve wold be a convenient tool.
Larry Woodfin 471W
Old 06-18-2015, 08:31 PM   #7
Sean Marconette
The fuel pump button allows me to push the button to fill the fuel sample cup, and is within reach of the fuel sample valve. No leaving the pump running to go thru fuel check.
Sean
Sean Marconette
84 Mustang
5060 SS/N
