#25 |
I usually do a good job of visualizing things in my head and knew how I wanted to lay out the cage, but I just couldn't seem to visual it with the car. My work as a design engineer gives me the opportunity to use some cool tools (if you didn't pick up on the 3D printed prototype part earlier) so I decided to model the basic car and lay out the cage.
![]() After adding some bracing to the front end, I cut of the rear of the frame stub to tie the main rails of the chassis in. ![]() Then a lot of cutting the remove the factory k-member mounts and structure. Here are the main rails slipped into the front stub. ![]() The #1 bar is bent and in place ![]() And finally the last picture brings everything up to date as I clearanced for the rocker bars and notched them to fit the #1 bar. The big floor beam in the center will be removed once the floor structure is welded in. ![]() Last edited by colby; 07-13-2015 at 10:36 AM. |
