Awesome news Mr. W. Can't wait for early spring at the Motorplex.
Liked 99 Times in 60 Posts
The Super 10 will soon ride again.
It was a good work day with block master Monte, he: *fitted the rings *removed all galley plugs *washed with soap & hot water *dried and oiled *block is on engine stand ready to assemble Monte doing the final drying. Next week the short block will be assembled
Larry Woodfin 471W |
A fine and cool East Texas morning with MSD 7AL-2 hot sparks
![]() The initial build was with an MSD 6AL which has given good service. With some trading between race packages this 7AL-2 became available so the Super 10 receives the upgrade. In addition for easier access the ignition is being moved from behind the passenger seat. Because the 7AL-2 has extra RPM module ports a plug in component can also be removed.
this allows both our race packages to become accustomed to each other, They will take turns being on top.
Liked 1,948 Times in 589 Posts
Larry
What is the HP rating for the 327 with the 585 quick fuel carb? I just picked up a 327 engine.
Mike Pearson 2485 SS |
Liked 115 Times in 35 Posts
Mike,
If I have this figured correctly in your car you would have to run GT with a factor of 293 auto. With a Q Jet a factor of 295 in super stock. I have looked at this for my 67 camaro. Seems to me the Q Jet would be worth the extra 2hp with the auto. In my car with a stick the small carb is 289 in GT. |
Mike,
it is the 1966 Corvette 327/300 @ 293 for SS/GT classes. the 585 Quick Fuel is a good carb. While I understand many racers run great with a Q-Jet I elected the simplicity of the Holley At 3170 pounds the Super 10 has run 10.40 in 2700 feet air. The original build has been improved in several small ways and I "expect" 10.20's this season.
