Old 06-17-2016, 10:05 PM   #11
rhinodaert
Liked 4 Times in 3 Posts
So I am assembling my Hemi to mock it up in my Hemi Dart and ran into a couple of issues. I have a 66 block and the correct aluminum water pump housing and the crank that came with it and it has the thick dampner. I need to know what diameter and height the crank and water pump pulley's are. I have two different crank pulley's and an aftermarket water pump pulley from Megaparts that does not come close to the water pump bolts. I do not have a timing gear or slinger on the crank so like I said I am just mocking it up so I can adjust the dampner to line-up with the alternator pulley. I believe the correct water pump pulley needs to be close to the water pump bolts, but not sure exactly what diameter and height the real on is.
