Old 12-08-2016, 11:18 PM   #21
Coleydog
Liked 53 Times in 38 Posts
Default Re: Lifter rule in Stock
Originally Posted by Eric Merryfield View Post
NHRA tech department clarifies recent lifter rule change
The change is to allow the use of a solid lifter in place of a hydraulic; you may not replace a flat tappet with a roller.
So what effect if any would there be on a 1993 build chrysler hydraulic lifter on a 383 big block. I assume new valve springs would be needed. Didn't change the rockers, still original as delivered.
Thanks
Eric
Can't see why new springs would be needed, better have adjustable rockers though. I thinking solids are lighter than hyd. anyway. Also a lot cheaper.
