Liked 100 Times in 51 Posts
[QUOTE=X-TECH MAN;555245]Maybe, but you would bankrupt all of the after market companies . That wouldn't be very good..........
Dan
Dan Foley SC 4698 |
I believe a little compromise on electronics would make the AHRA version a lot more palatable for all. Lack of spectators seems to be the big problem, and spectators would have no idea if there were a delay box or rpm shifter on board. We turned a 9.50 car into a deadly 10.00 index car with a 3000 launch chip, altering shift points and a bolt under the loud pedal. Class was a blast and extremely competitive. So keep most of the aftermarket electronics(and manufacturers), run heads up that makes more sense to the casual fan, and the only ones hurt are the throttle stop manufacturers. I would gladly put my stop in the trash can if everyone else did.
And another aside, Dragway 42 is running an 8 race index series with no stops or delay boxes. A little more challenging but level playing field for all. May be the way of the future to try and put some fans back into the stands. |
