Old 04-21-2018, 01:48 PM   #11
Ed Wright
Ed Wright's Avatar
Default Re: 12 Bolt vs 10 Bolt Rear
Vehicle weight is a big deal. Moser may offer a bolt-in 12 bolt. I would check with them.
Ed Wright 4156 SS/JA
Old 04-21-2018, 09:43 PM   #12
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Dan
Isn't that a 7.5 inch 10 bolt in the Impalas. ? I had to run Pro Gears in my 68 Impala, broke street gears, but then again a 4000 l b BBC stick car at that point. Running same 4:88's in my 65 automativ car.
Will Lamprecht
65 Impala 396/325
Old 04-21-2018, 11:21 PM   #13
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by impstocker View Post
Dan
Will Lamprecht
65 Impala 396/325
Camaro’s and Firebirds got that rear.
B-body’s got the 8.5 inch rear.
None of us in the Impala club are having problems.
Unless they are using a Stick.
Chipper brought up that the 8.5 rear uses the same bearings as a 12 Bolt.
That makes it stout.
Wonder if a 12 bolt ring and gear and Spool will fit in a 8.5 Pumpkin?
Old 04-21-2018, 11:34 PM   #14
Dan Fahey
Dan Fahey's Avatar
Still trying to figure out the best gear ratio.
Using 4.56s with a 4L60E trans.
Not using the locking converter now.
Looking at 5.38’s and locking it up in high gear.
I can program that in the PCM...
Hope to get close to the K/SA index with current cam.
Old 04-21-2018, 11:44 PM   #15
Not correct.
The Impala SS may have all come with the 8.5.
Pinion bearings and flange are different, for one thing.
8.5 and 12 bolt take different side shims.
Old 04-22-2018, 07:56 AM   #16
Dan Fahey
Dan Fahey's Avatar
Not correct.
The 91-96 B-boys are the Caprices, Impalas, Roadmaster and Caddy’s.
All were 10 bolt 8.5 rear
Camaro/FB all came with smaller 7.2 rear.
They can surprisingly survive with a good bit of power too..!
About a $1k less to beef up a 10 bolt than installing a prepared 12 bolt unit.
They make them to fit our B-body.
Interesting being the same suspension configurations as the early Chevelles, GTO, Cutlass, GTX.
D
Old 04-22-2018, 10:09 AM   #17
Rick Schilling
Liked 14 Times in 10 Posts
Generally the B bodies with the Baby LT-1 or 305 have the smaller rear. The LT-1's generally have the 8.5 (Impala and Caprice).
Rick Schilling is offline   Reply With Quote
Old 04-22-2018, 10:36 AM   #18
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The later F-Bodies got a beefed up 7.5 rearend , with a bigger 7 5/8" ring gear .
Old 04-22-2018, 10:50 AM   #19
james schaechter
Liked 1,436 Times in 299 Posts
With the money you save from staying with the 10 bolt you can probably afford a golf cart and a tow strap. Eventually, you will need it.
James Schaechter 3163 STK
Old 04-22-2018, 11:49 AM   #20
Shhhh..Don't tell Dan. He's spent too much time on the SS forum, and not under those cars.
Whatever you do , don't tell him the early Chevelles did not have the same suspension. Although it looks similar, it is not a metric configuration.
Also , I have never seen a bolt in 12 bolt for those cars. Maybe those SS guys can help him. Apparently we are not qualified here.
