Liked 99 Times in 60 Posts
Terry,
if I can run a Powerglide with the 350/360/325 that will sell the deal. I would much rather run the glide than a 3 speed.
Larry Woodfin 471W |
Liked 239 Times in 114 Posts
Doesn't reverse direction on the 1-2 shift , but does come to a stop . Then spins up the same direction as the engine when making a 2-3 shift . The Superlight reduces that inertia dramatically for both those shifts , that is why it's so fast !
Liked 133 Times in 76 Posts
Which part are you talking about? There is no drum for low/reverse only drums are forward and direct.
Both the 350 and the 400's High gear housings spin opposite engine revs in 1st gear , come to a stop in 2 gear , then spin with the engine in 3rd gear . This is true with the 200, C4 , C6 , 904 , and 727 , which have similar powerflows .
Liked 5,121 Times in 1,952 Posts
The direct drum makes high and reverse. Not low/rev.
This is the drum we're talking about. Maybe that's where the confusion is from.
OK, Direct drum is what I thought was meant as that's the drum with the sprag on it.
