Liked 28 Times in 15 Posts
when I built the Comanche nobody listed front disks for it.
I contacted aerospace and they said to send them a spindle and they could build the mounting plate (everything else is 5"X4 1/2 and available). ended up charging me $65 extra over the regular kits - and they have been on for 14 years. Very satisfied with the brakes and the customer service. Works for me. 1051 R/SA |
Liked 8,210 Times in 1,536 Posts
Everyone shoots for a nice FIRM pedal but I haven’t seen one post regarding DRAG......Absolutely NO drag with the Lamb setup....Aerospace not so much, but they do supply you with washers to shim their setup....
Liked 886 Times in 238 Posts
The big knock on Aerospace is not so much how they work, They use the same pads and piston sizes as every other manufacturer .
The real issue is quality control and component packaging. I've installed every other brand out there for customers and not once did I need to re drill holes, or counter sink them or run to the bolt bin for correct hardware . ....not the case with Areospace. Caliper alignment also an issue with them witch causes soft ,spongy pedal feel. all correctable issues ,but I'll take Strange ,MW Lamb or Willwood over them any day.
Liked 22 Times in 22 Posts
I had aerospace on our cobalt, and the drag was tremendous. If we bring it back out, I’ll put Lamb brakes all the way around. They drag so bad when he’d pull into the pits and clutch the car, it’d slide both fronts.
don,t have one |
Liked 1,968 Times in 595 Posts
I am with Ed on this one. I have had Aerospace on my car for quite a few years. They have worked flawlessly. There is absolutely no drag. I can spin my fronts and they are very free. I also have a nice firm pedal and don't have to do any pumps of the pedal.
One thing that will cause drag Is if you are heavy on the brakes at the finish line it will wear the brake pads on a skew and they will drag like crazy. A nice soft touch on the pedal and the pads will wear evenly. I have installed Aerospace brakes on several cars with excellent results. They are a good company with good people and customer service. Now if they aren't installed properly then that could be the problem.
Mike Pearson 2485 SS |
Liked 66 Times in 12 Posts
In my younger years all I looked at was price, so I converted my Stock Eliminator car at the time over from factory disc brakes, to Aerospace because they were cheaper than their competitors. They looked pretty, but that was about all they provided, dragged terrible, pedal sucked, wore pads, just a complete nightmare.
Sent them back to Aerospace multiple times just to have them tell me I installed them wrong. Finally bought a Strange kit, simply unbolted the Aerospace and bolted up the Strange, and all my problems disappeared. Some say they have had zero problems with Aerospace, but I think you will find most have been unsatisfied. Just spend a little more and buy good parts, it will cost you less in the long run. |
Liked 314 Times in 177 Posts
My first set of racing disc brakes was in 1978, Hurst/Airhearts. Since then I've used JFZ, Strange carbon/carbon, Wilwood, M W and lately Strange steel. Over this time period I've noticed changes in the Strange brakes that show me their committed to improving their product, ie directional calipers using different size pistons. Also the front kit uses aluminium hubs designed to fit one bolt circle not both. ( either 4.5 or 4.75 ) This saves on weight. Overall, IMO, Strange is the best value.
