Old 05-08-2018, 05:06 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: Transmission Converter Options
Originally Posted by ss3011 View Post
Totally agree with you . I had probably the first stocker to run a 200thm in my 83 307 Cutlass . Definitely faster than a 350 or a 400 .
I think Dan wants to work with a 4L60e , and that's cool too ! There are a lot of large diameter steel drums inside that beast , and I am not sure if any aftermarket company making aluminum replacements .
4L60E is what I have and know and it is built up.
For now going with what I have.
A built 200thm costs a good bit.
The R700 and 4L60E are stronger, right now prefer reliability.
They have similar internals.
Should already have some light weight race components.
This is a good conversation.
D
Old 05-08-2018, 09:21 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Feeling pretty good about my current Coan Lite TH350 w/low gearset vs the metric 200 so far.
Rich Taylor
I/SA - 321
Old 05-08-2018, 09:49 PM   #3
Sam Lusco
Sam Lusco's Avatar
I know someone with a 200 for sale with only 4 or 5 runs on it.
Sam Lusco is offline   Reply With Quote
Old 05-08-2018, 09:57 PM   #4
Dan Fahey
Dan Fahey's Avatar
Coan makes good transmissions!
Liked them when they started business in the early 80s.
The Metric 200 is fine for a lighter car.
4000lb plus weight you need a wider clutch and HD internals.
D
Old 05-08-2018, 10:42 PM   #5
HandOverFist
Yes, durability was the driving factor for my switch to the TH350 vs the metric 200. Not realizing any performance loss so far with the change...but my junk has always been slow.
Rich Taylor
I/SA - 321
Old 05-09-2018, 12:14 AM   #6
Mepprecht
Mepprecht's Avatar
Liked 68 Times in 26 Posts
Don’t dismiss the 200 if it’s built right. My p/sa car had it from corbitt, when it was above 4000 lbs. They are also used in a lot of heavy cars in stock like some copos. Turbo action did my 200, jack sepanek fixed my pump after 8 years problem free. My little 265 qualifies very well with a 200.
Mike Epprecht
94 caprice P/SA - SS/PA 265
Mepprecht is offline   Reply With Quote
Old 05-09-2018, 06:05 AM   #7
Painter
Liked 162 Times in 45 Posts
If you are having trouble with a 200 Metric it is not the transmission. It is how it is driven in the pits and water box, chassis flex or transmission assembler. I get 200-300 runs out mine all the time and take them out because I am embarrassed that I haven't had them serviced! Paul Forte builds a great transmission.
Painter is offline   Reply With Quote
Old 05-09-2018, 08:19 AM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The transmission cares more about how much torque is being inputted , not so much how heavy the car is . Now, there are many 455 Pontiacs and BBC running 200THM , so there are many parts available to beef up the weak points . One interesting modification I like is a 350/400 input shaft spline , and modified pump , which allows you to run a 350/400 converter . What is neat is a 200thm was meant to replace a 350 , so the length and output spline is the same . With a modified spline and pump , you can then also use the same converter . I bet there are a few Racers out there that know just how much faster a 200thm is compared to a 350 .
