Old 06-01-2018, 06:40 AM   #18
Marty Buth
Liked 232 Times in 39 Posts
Default Re: A/F readout delay
Marty, if your car is EFI, make a big change at like 6000 RPM, then see what RPM it shows up on your logger. I mostly look at high gear, since the A/F vs RPM error is going to be greater in lower gears due to the RPM increasing so much faster. And, I assume, if you leave off a 2 step, that your launch A/F looks much leaner due to the misfires caused by the 2step. Misfires put more oxygen in the exhaust, and our Wide Band O2 sensors calculate the air/fuel ratio by oxygen content.
I hope if you already knew all this, I didn't offend you. Maybe somebody did not know. Not trying to be a know-it-all.
All good Ed, definitely not offended. I did know about the 2 step. I hadn't thought about altering fuel counts at a specific RPM to track the delay. That is a good idea. Thanks Ed!
Marty Buth 3657 STK
Marty Buth is online now   Reply With Quote
