Liked 9 Times in 5 Posts
What would the best approved fuel be for a 9.5:1 dish piston 305 2bbl?
Liked 184 Times in 113 Posts
Liked 68 Times in 26 Posts
Most popular fuel is probably C11 in stock across the boards. That or c12.
Mike Epprecht 94 caprice P/SA - SS/PA 265 |
X2 for C11 with that compression in our Stockers.
#5 | |
Liked 50 Times in 23 Posts
The Sunoco 260gtx is an unleaded fuel, similar to VP C-10, easier on the A/F wideband sensors esp for the late model and dual duty street/strip use cars, although most guys on here will use the leaded fuels (C-11, C12) etc. to extend valve train life and achieve higher octane ratings. Another issue is availability, a racers preferred fuel may not be sold at certain tracks... Thanks to MG raceway for posting this chart.. http://www.maplegroveraceway.com/wp-...-reference.pdf
Steve Stickel 1161 Stk 1167 SS |
Liked 182 Times in 61 Posts
Run c-11 in my 81 305 dish motor . run about 3 hun.faster that c-12
#7 | |
I can find it and less expensive than C10. RKelliher said that running C11 works better than C12. How does is work that one Octane Fuel works better than another? Dan |
Liked 24 Times in 13 Posts
Consistently, on a dyno, my engine makes 1% more HP with C11,
compared to VP110 or Sunoco Standard. Terry K |
We also are faster with C11 than C12 in back to back testing
in our low compression Stockers!
Liked 1,955 Times in 590 Posts
C-11 was designed especially for low compression stock and super stock applications. Its not always readily available so you have to plan ahead and get that fuel ahead of time. C-12 is much more readily available and a bit cheaper. Not as fast in the low compression engines as the C-11 but runs very well. To get full advantage of the C-11 it takes a jet change as I remember. I run C-12 in my super stocker
Mike Pearson 2485 SS |
