06-21-2018, 04:52 PM | #141 |
Liked 518 Times in 154 Posts
Re: 2015 Mustang Ecoboost K/SA?
Last portion of this post was very instructive.
Keep on, Charles Stewart |
06-21-2018, 05:00 PM | #142 | |
Liked 1,749 Times in 424 Posts
As far as the rear end width, you will have to consult the tech department. My thought is that they allow "factory spec. replacements. |
06-21-2018, 05:47 PM | #143 | |
Liked 117 Times in 50 Posts
Do I have that right? |
06-21-2018, 05:52 PM | #144 | |
06-21-2018, 08:04 PM | #145 | |
I just don't want to spend $20K or so on a retirement hobby, just to get torpedoed by something that I never saw coming. Again, I have no interest in setting a record or racing at Indy- I just would like to be able to comfortably run under index. |
06-22-2018, 07:24 AM | #146 | |
Liked 324 Times in 116 Posts
http://www.nhraracer.com/content/gen...633&zoneid=132 There have been times where a racer ran 1.19 under once and for the rest of the review period ( every 6 months) never ran more than .999 under index again, and the combo did not get a hp increase at the end of the review period.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
06-22-2018, 07:27 AM | #147 | |
I ran 1.4x under on my first pass in NHRA Stock with the car in my avatar and set the Q/SA record the same day.. There was no way I could have gotten a legal Stocker to run that far under index if I had built it myself for that amount of money. If you want to go bracket racing with a class car, then the Stock Eliminator field is less populated in the (lower letter) classes so the odds of a heads up pairing ( with another vehicle the same class as yours) during eliminations is greatly reduced. For $ 20K you could probably buy a turn key car, open trailer and a decent pickup tow rig
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 06-22-2018 at 07:36 AM. |
06-22-2018, 08:17 AM | #148 | |
Liked 6,966 Times in 1,570 Posts
Now that's some really good advice right there!
Billy Nees 1188 STK, SS What is "NORMAL"??? |
06-22-2018, 11:27 AM | #149 | |
Liked 187 Times in 68 Posts
The three I've drove (one being my daily driver in a f150) works fine, floor it and at 3000rpm it starts to pull hard. It doesn't "nose over" on its way to the factory shift point of 6750RPM!! This is a pick up motor! I thought it was a fluke but have driven two new transit vans with the same motor and same results. So, in a mustang with loose converter and some gear? I can't imagine it NOT being a rocket. First gear in the 6spd is quite low so 4.56 would probably be as low as you need otherwise the 1-2 shift would be before the first revolution of the tire. lol. Bottom line, I see a ton of potential in this engine, good flowing heads/strong bottom end and the throttle valve seems to be a good size too although I've never actually measured it. Love to see one run. |
06-22-2018, 12:11 PM | #150 | ||
