Liked 2,487 Times in 698 Posts
I ran cast pistons and a low tension oil ring or TRW replacement
forged pistons for many years. They worked fine....just not the optimal set up. I still run a cast piston in my high ten second bracket car and it works fine. You will not be a second under BUT should run under the index on the cheap.
