Old 06-07-2019, 10:11 AM   #1
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Default Re: Fuel in intake
It made a huge difference in the idle. from what I see, the first gasket blocked the source of manifold vacuum that feeds the PV. I think the PV was opening during idle. At least that is my new theory. Spark plugs are now dry as well.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 06-08-2019, 10:28 AM   #2
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Fuel in intake
Make sure you have some sort of 4 hole gasket or something else, like a 4 hole thin spacer, to keep a base plate to bowl screw from getting loose and backing out and falling into the engine through the intake! Holleys do that.Could save you an engine.
Old 06-08-2019, 09:09 PM   #3
GallopinGhost
Thanks Greg. Good point. My theory #2 didn't pan out. Although I've seen fuel stains where there shouldn't be any, so trying a few things. Pretty annoyed with this carb as it's fresh from one of the name gurus, but I guess it's a good training experience for me.
Brian Carpenter
Stock 1358
Old 06-09-2019, 12:21 PM   #4
GallopinGhost
I think I've fixed this issue. I had thought the PV was opening because of the base gaskets. Well I found that fuel was collecting in the vacuum space in the body behind the PV, and was being pulled in thru the vacuum port thru the baseplate. Gaskets were leaking bad on both ends. I re-surfaced both ends of the body where the fuel bowls go. Amazing how bad a shape they were in once I started working on them. I will never build a carb without doing this. The vacuum space is dry on both ends now and spark plugs are also dry. Still a little fuel in the intake, not going to worry any more about that. I'll see how it runs. I won't mention who built this carb, but he was recommended in a thread I started here. Stevie Wonder could have diagnosed this problem. And thanks to all that helped. On to the next problem......
ID:	50228   Click image for larger version
Brian Carpenter
Stock 1358
Old 06-10-2019, 02:20 PM   #5
GallopinGhost
Thought I should add this. I talked to the carb guy today, he apologized for how things went and offered to do another carb on his nickle. Can't ask for a better conclusion than that.
Brian Carpenter
Stock 1358
Old 06-10-2019, 02:58 PM   #6
Liked 11,007 Times in 2,263 Posts
Raw fuel through the vacuum port, I'm glad you found it.
Old 06-10-2019, 03:05 PM   #7
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
When i worked in the carb shop at AED in Richmond Va every carb we did we surfaced the ends of the body. Brand new castings from Holley are crap out of the box.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
