Old 04-06-2019, 06:29 PM   #221
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: My 88 Olds wagone U/SA 10 Pennies
Originally Posted by Jeff Stout View Post
Old set of bias ply. At 20 lb cold
Try to get a pair of used radials,start at 25 lbs if it hooks add more. There's your tenth maybe more.Good bang for the buck!. gsa612
Old 04-06-2019, 09:50 PM   #222
Rick Kolber
Liked 32 Times in 13 Posts
Jeff, You have a PM.
Rick Kolber is offline   Reply With Quote
Old 07-04-2019, 03:34 PM   #223
mopacltd
Liked 124 Times in 44 Posts
Any updates, Jeff?
mopacltd is online now   Reply With Quote
Old 07-05-2019, 10:06 AM   #224
Jeff Stout
Liked 708 Times in 285 Posts
Heat in Az.has stopped me. 14.51 best so far by just jetting richer. Going to tighten converter as it is way loose. Then a couple different collectors to try. I still think 14 flat can be made in decent air.
Old 10-06-2019, 10:01 PM   #225
Jeff Stout
Finally went testing before div 7 race next week. With the converter having 11% slip I tried the john deere hydraulic fluid in transmission. Sure enough it worked. I reduced finish line rpm by 300. By having less slip and running my weather station stats from the spring testing I gained .06 in ET. Even though it's not enough lock you in high gear it will get me by for next weekend.
Old 01-14-2020, 12:47 PM   #226
Jeff Stout
Little update of work performed. Changed from a 6.14 gear to a 5.57. Hoping to use motor torque to accelerate car. Front end alignment. Front end had severe toe in. Took front GM brake calipers off and freed up movement in hopes to keep pads away from rotor. They had allot of drag before, now they barely touch rotor when spun. Moved some weight to the back as I moved some to the middle of car and 60ft slowed. Installed cool fuel can. Installed fuel pressure gauge and found out I had been running 7lb of fuel and was wondering why car had a blubber to it. Had a cheap gauge mounted right at regulator and was reading wrong. Racing team race this Sunday and see if anything helped.
