Old 07-13-2019, 02:24 PM   #1
Eman
Liked 133 Times in 76 Posts
Default Re: MSD 8732 2 step sporadic fail
As stated above it's not legal if that is an issue. Then I wonder what the theory is of using a relay. The 2 step obviously doesn't use much power. Generally controlling the transbrake solenoid with a relay isn't done or needed. Don't see what good a relay is going to do. Still think you have a bad connection somewhere.
Old 07-14-2019, 11:10 AM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Are we talking about a stocker with a brake pressure switch????
or
A super stocker with a transbrake button????
I'm confused?????
Bob Mulry 7516 STK
A & M Motorsports
Old 07-14-2019, 05:23 PM   #3
Biscayne
Biscayne's Avatar
Liked 2 Times in 2 Posts
Friend of mine had the same problem on a stick car with a 7AL 2. We would only only change the 2 step launch like 200 rpms and it changed like 800-1000 rpms when he actually put it on the two step. Its the diff switches that are the problem. A lot of guys have the same problem. He switched to The Grid. Problem solved.
Scott Chalk 1226 I/SA
Biscayne is offline   Reply With Quote
