#161 |
Liked 370 Times in 101 Posts
I know exactly what you mean, one day forward-three days back !
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#162 |
Liked 10,902 Times in 2,255 Posts
I believe the engine will pass a NHRA teardown, parts, lift ,size, stroke, cc's. I need to get a few gaskets,spare parts, and I should be fearless, nervous but fearless, for teardown.
Do plumbing, make travel caddy, get fuel, load and go to dyno. Cross your fingers. |
#163 |
Liked 450 Times in 133 Posts
Larry that intake looks sweet, can't wait to see you and Patsy make some passes. do you think you will have it out this year ?
Jerry Retired 3490 3492 STK- SS-SST |
#164 |
We planned to race it in March of this year, but that didn't happen. We hope to have it at BG in Aug. If things go bad we will put the pink car in service.
#165 |
Liked 493 Times in 231 Posts
Plan on being at Indy ?
Jake Biermann |
#166 |
Yes!
I'm loaded up, had to remove intake to load. And I'm off.......... |
#167 |
Today is the day we try to fire it up
#168 |
Liked 3,230 Times in 982 Posts
You at Taylor’s shop for the dyno work? If confidential no problem
#169 |
A BIG Thank You to Cooter and David for working so hard and smart on getting the "Bugs" worked out so "Dumbo" would start and run. A lot of the bugs were self inflicted by me. Just because a sensor worked in a 6.1 does not mean it will work in a 392 after its installed in the same place. Other problems were parts that checked good but did not work, for what reason who knows. Cooter and Dave worked and trouble shot on the system from 8:00 am until 2:20 pm. that's when the engine came to life. I'm telling you these guys so worked hard you would have thought it was their engine they were trying to start.
All of this happened Friday and I was hoping to get home Saturday. I did! Cooter was also a cheer leader all day, as they solved one problem and went to another he would cheer me up by telling me the truth, they were making progress. I forgot to tell you folks that this was Cooter's first Gen III Hemi. I'm sure if it was a LS-1 things would have been much easier for Cooter. The worst thing for me was the limited things I could reliably do to help. I will be better. I will write more of the FI Dyno experience. The emotions grafted would have more ups and downs than the sine wave of three phase electrical current. I have to thank my friends Jeff Teuton, Shaun, and Sid for all the help to get "Dumbo" ready to fly! --- I hope! |
#170 |
Clean up on Aisle 1
