Old 08-19-2019, 08:03 PM   #1
J&S Racing
Liked 327 Times in 87 Posts
Default Re: 69 Camaro B/S
Ok... enough sulking about the new dragster motor, I’ll get into this later but for now it’s time to get back on this stocker.
Honestly, if it was mine I'd face the mounting bosses off about .125 to move the box laterally. The rag joint should accomodate this. The column could be loosened up and lined up accordingly, as well. Then, no header gasket...just a thin bead of sealer like Valco Aluminized silicone.
For what it's worth. -Al
So after some back and forth we decided to give Alan’s idea I shot rather than a “technical tap” on the header. We took about a 1/8 of the bosses and looks like I’ve got plenty clearance even with the header gasket.
Some needed stuff also arrived.
RobbMC starter and battery cables to finish out the wiring
Old 08-20-2019, 08:14 AM   #2
Alan Nyhus
Liked 799 Times in 236 Posts
Glad it worked out. I did it for clearance on #7 and the box. -Al
"That'll never work....."
Old 12-22-2019, 08:42 PM   #3
J&S Racing
Time for a little update....
Once the car was on the ground I felt the seat brackets I made had me sitting a little high. I ended up with these from Rhodes race cars. Much more comfortable and still bolt in stock location.
Plumbing and wiring is just about finished up under the hood.
Old 04-16-2020, 04:37 PM   #4
J&S Racing
Hope everyone is staying safe and healthy!!!
Figured time for a update.
1st off a huge thanks to Glen Sanders. Not only are his rims a thing of art his customer service it top notch!
My original plan was to use the newer style willwood master cylinder. I also wanted to use the bickel brake rod retainer but it turns out they won’t work together.
I decided to just use the Mopar style, I didn’t really want to open and elongate the mounting holes so I found this trick adapter from TRZ Motorsports.
The hole was 5 thou small for the Bickel kit, a little sanding and it fits together perfect.
Old 06-29-2020, 10:08 AM   #5
J&S Racing
Big thanks to Mark Markow race cars in south Windsor CT.
Was able to cross a bunch of big stuff off the list..
Had the rear end centered up and pinion angle set then welded the Calvert perches.
Also had him add a tab for the racepak censor. The pick up had to be machined to fit around the yolk.
Added a net
Getting the car set up for weight has been on my mind for a while. Mark nailed it!! Also provisions above the axle for the small bars and brackets where the rear seat would be for the large bars.
Old 06-29-2020, 09:45 PM   #6
B Parker
Liked 2,343 Times in 465 Posts
Used Mark several times. Nothing but the best from him. Hope to see your car out soon. BP
Old 08-23-2020, 11:36 PM   #7
J&S Racing
Yesterday was a good day!!!!
Took my old mans hauler project out for its maiden voyage. Dragged the car up to Epping Sunday afternoon for chassis cert.
