Old 09-02-2019, 05:58 PM   #1
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Default Re: Dumbo The Flying Elephant
Is this a 426 combo car, hence the Elephant (Dumbo) reference?
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 09-02-2019, 10:38 PM   #2
Liked 10,750 Times in 2,235 Posts
Its a baby Elephant, 392, that's why its Dumbo. If it was a full grown HEMI it would have tusks and a much more menacing look.
I think all will be well after the water is kept in place. But trust me I'm not shy and I always want to listen to different ideas.
Thanks HB2, I have a plan of attack and need a little time to set it in motion. But to be honest a few more magic feathers might come in handy!
Old 09-03-2019, 11:31 AM   #3
Rod Greene
Liked 242 Times in 81 Posts
Back to the Pink Lady to gather some points?
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 09-04-2019, 09:03 AM   #4
Frank Castros
Liked 2,735 Times in 965 Posts
Ten LODRS events left this year. Plenty of opportunities.
Old 09-04-2019, 08:59 PM   #5
Rod Greene
Did Patsy break her camera? Where are all the pics?
Old 09-05-2019, 09:38 AM   #6
FED 387
Liked 333 Times in 180 Posts
Years ago when we had porosity problems while running aluminum Oldsmobile small block heads in Modified we encountered weeping or sweating-- our solution was to use either Alumaseal the powdered stuff or something called "Water Glass" or sometimes called "Sodium Silicate" I think is the actual name for it--we got that stuff from a Pharmacy !! The farmers used that stuff on chicken eggs before refrigeration and would dip the egg into and could leave it on the kitchen counter for a few weeks and the eggs would not spoil---Not sure how bad your situation is but both methods either separately or together solved our problem. BUT before you go into tearing it all apart you might give it a try. Good luck interesting build have been following it and wish you well
Old 10-16-2019, 05:52 AM   #7
After Rockingham I should be able to make some progress on "Dumbo''. Plan of attack is put on rack, drop oil pan, fill and pressurize cooling system, and determine the source of leak. Remove engine, disassemble, inspect, repair, hone cylinders, assemble, dyno, install, sort out car, go to the Gators.
That should keep me busy for a few days.
