Liked 508 Times in 92 Posts
Do yourself a favor and save up for gun drilled axles, they are worth it. Also, if you're going to put an exhaust system under the car, get electric cut outs. I have both on my car and it's fun to race with.
Casey Miles 248H E/S |
Liked 186 Times in 48 Posts
I've used gun drilled axles before (first set was in 1996), but this car will see street use so its conventional axles for this go-around.
If you're going to put on an exhaust system, on my 1969 Camaro Z/28 I have a 2.5 inch flowmasters with electric cut outs. The car will run only .15 to .18 slower through the mufflers rather than open headers and they are pretty quiet. Just a recommendation from experience. What I do is run the car with open cutouts, qualify with that number, make a pass with mufflers and dial the car through the mufflers.
Casey Miles E/S |
#4 | |
Here's an update on my Nova Build. This is actually part 2 of the rear end video. This one discusses axles. You might find the tech interesting.
While working in the shop (and in this case, on my sleepy little Nova project) I regularly stumble into "problems". So I have to come up with "solutions"....L-O-L. And some of those solutions turn out to be good old-fashioned garage hacks. I compiled six of them in video format that actually worked pretty well. They're certainly not fancy and they're sure not expensive. Check 'em out (click to view):
Here's an update on my Nova build. If you dig it, please subscribe to my YouTube channel. I need all of the help I can get...L-O-L. And thanks for watching!
