Old 11-21-2019, 08:30 AM   #181
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Nova stocker project.
Originally Posted by Sean Marconette View Post
Alan, Good luck during the off-season! No rest for those in a performance based category, as there is always something to improve on or look at.
Sean
Sean, congrats on setting the SS/N National Record at Kearney! Doing it with a 4 cyl. turbocharged combo is impressive, to say the least. -Al
"That'll never work....."
Old 11-21-2019, 08:56 AM   #182
jimmyparker
Liked 309 Times in 88 Posts
Allan,
When the 327 out of my '68 Camaro was torn down for a refresh the cam looked like yours, eat up pretty bad on both sides of the lobes. The Schubecks didn't show any kind of wear as usual. It only had 170lbs on the seat and always had Gibbs oil in it. I was going to buy a billet replacement but there was a backlog on them at that time so I put a cast back in it. The car and motor are gone not sure what it will look like at the next teardown. My engine guy was puzzled as to what actually caused this condition.
Jimmy
jimmyparker is offline   Reply With Quote
Old 11-21-2019, 10:13 PM   #183
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Thanks Alan!! Setting a record has been on my bucket list since getting into class racing.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 11-23-2019, 09:45 AM   #184
Alan Nyhus
Originally Posted by jimmyparker View Post
Alan, When the 327 out of my '68 Camaro was torn down for a refresh the cam looked like yours, eat up pretty bad on both sides of the lobes. The Schubecks didn't show any kind of wear as usual. It only had 170lbs on the seat and always had Gibbs oil in it. I was going to buy a billet replacement but there was a backlog on them at that time so I put a cast back in it. The car and motor are gone not sure what it will look like at the next teardown. My engine guy was puzzled as to what actually caused this condition. Jimmy
Hi Jimmy. This cam had over 200 runs on it. It was nitrided, broken in with light springs and oil used was either Valvoline VR1 10w30 or Redline 5w20. Lifters were uncoated Trend w/o an oil hole. I'm not sure if more or less lash would make a difference or not. I'm not unhappy with the life of the cam, though. Short of going with a billet or 8620 cam core, there's not much else to be done.
Trend polished and recrowned the lifters. I just can't bring myself to put ceramic faced lifters in the thing....
Good to hear from you, hope all is well. -Al
Old 12-19-2019, 09:22 AM   #185
Alan Nyhus
Got everything back from Matt Steen's Victory Engines in Marshall, Mn. and started going back together.
Matt and Jason Verke are precision machinists that specialize in Stock and Super Stock engines, cylinder heads and intakes. They work on a one-on-one basis with each customer and are professionally confidential with your project.
Matt Steen (left) and Jason Verke (rt):
Matt's SS/K '66 Valiant 273 is a familiar sight at NHRA Division 5 and Midwest Class Racers events. To take an obscure combination like this and make it run hard gives a little insight to Matt's intellect and work ethic:
Jason is a true artist on heads. He knows what works and is constantly tweaking. No cookie cutter head work, here!
Old 12-24-2019, 12:08 PM   #186
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Wow, I bet Matt gave you quite a discount for all that glowing publicity!!
Paul Merolla is offline   Reply With Quote
Old 12-24-2019, 01:59 PM   #187
Liked 5,137 Times in 1,960 Posts
Curious as to what kind of power that 327 makes,
and to jumble up the numbers a bit, that 273?
Old 12-25-2019, 09:31 AM   #188
Alan Nyhus
Now, Paul....you know better than that! -Al
Old 12-25-2019, 06:05 PM   #189
Alan Nyhus
Mark, Matt's been low 10-teens in SS/K (2,900 lbs) in decent air. -Al
Old 01-10-2020, 08:28 PM   #190
Alan Nyhus
Pics from today:
