Old 02-02-2020, 08:54 AM   #1
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Some Goats.
Name:	Rocky's Goat .jpg
ID:	53668   Click image for larger version
Name:	Tiger-rific '67 .jpg
ID:	53667   Click image for larger version
Name:	Swanson B-S .jpg
Name:	Pampered Papoose .jpg
ID:	53665   Click image for larger version
Name:	Big Iron D-S .jpg
Old 02-02-2020, 11:24 AM   #2
oldskool
oldskool's Avatar
I'm gonna present my opinions here. Then I wanna get opinions from you Pontiac guys.
(1) The first thing I want your opinions on, is what would be the cheapest Pontiac combo, that could be easily made to run safely under the index, & even survive a couple of small index reductions.
My opinon:
I think a '77 180hp 400 would be the cheapest, when used in any legal body EXCEPT a Bird. The NHRA hp factor is 260.
http://www.classracerinfo.com/Engine...4&MAKE=Pontiac
There are still some good blocks out there for around $600 or less. Most any good 400 block will work, EXCEPT the infamous "557" blocks.
The required 6x-8 heads are probably the cheapest & most plentiful 400 Pontiac heads there are. Usable cores are still going for around $200 a pair, or less.
Adam Strang has proven that you can get by with the cheap Speed Pro forged pistons. That savings will pay for the price of a core block.
That engine can use an 800cfm Q-jet.
This is no secret or surprise to anybody, since there have been so many Pontiac Stockers run this engine.
(2) Next question is: What is the best Pontiac combo, IF there is no budget limit at all. Another way to say it is: ...if cost does not matter.
I'll list several which I think MIGHT be best. The oldest one is a Ram Air II engine in a '68 Bird. 340hp factor. The cam can have nearly .500 lift.
http://www.classracerinfo.com/Engine...3&MAKE=Pontiac
The Class Racer Info site just quit working, for me. Anybody else ?
The 455HO engine has always been competitive. I think it still is. I assume that Brad Burton is the most famous 455HO guy, in recent years, with national & div championships.
Well, I'll stop this 'til the CRI site starts working again. Then I'll edit & continue.
OK, it's back up. The factor for a '72 455HO, in a Bird, is 325hp. IMO, that's a competitive combo.
http://www.classracerinfo.com/Engine...9&MAKE=Pontiac
The '73-'74 D-port 455 has a 306 hp factor, in Birds. Michael Brand & Adam Davis proved that is a competitive combo.
Then, of course, for those who can afford the high dollar factory parts, the '73-'74 SD455, in a Bird, is still a competitive combo, at 335hp.
http://www.classracerinfo.com/Engine...0&MAKE=Pontiac
Even at 356hp, the '69 Firebird should still be competitive, with the round port RAIV engine. Besides the round port heads, it has high compression, & a cam with .531 lift. Like the SD455, the RAIV parts are now rare & expensive.
http://www.classracerinfo.com/Engine...2&MAKE=Pontiac
Another combo I like is the '70 GTO, with the 360hp D-port 455. It has a 340hp factor. But, it's high compression. Only one of these cars running in recent years, that I know of. Don't know what an all-out build would do.
The '74 400 is still a possibility, since you can run it in a Bird, without a penalty. But, in other bodies, the '77 400 has a 15hp advantage. In recent years, the '77 has been run in the Lemans, the Grand Prix, & at least 1 Catalina.
At a 333hp factor, the '68 Bird, with the 330hp 400, is still competitive.
I've mentioned that he same engine in a '68-'69 GTO, has only a 325hp factor. I ask but never got a response. So, is the GTO body enuff to offset that 8hp difference ? Or, would a GTO be slightly more competitive, with the same engine?
I personally like the extra torque of the 455 engines. So, when the hp factors are pretty close, I favor the 455 over the 400.
So, with price not a concern, what Pontiac combo do you guys think would be most competitive, in an all-out, no expense spared build ?
And, while we're at it, I think I've read where both Bill Rink & Mike Morgan have said that Parsons & Myers can build the quickest Pontiac engine. What say ya'll ?
Old 02-02-2020, 11:55 AM   #3
Billy Nees
Liked 7,783 Times in 1,743 Posts
The biggest issue that you're going to have in building the "cheapest" Pontiac combo is going to be finding a body. Where are you going to find a "cheap", decent (not needing to spend 5K and a year in body shop prison) car?
Billy Nees 1188 STK, SS
Old 02-02-2020, 08:58 PM   #4
oldskool
oldskool's Avatar
Yeah, that's a good point.
My thought is that anybody who'd attempt to build a really CHEAP Pontiac powered Stocker, would have all the basic skills to build a car from the ground up.
For example: My neighbor is a long time Pontiac guy. He's built & raced quite a few Pontiac bracket cars, including a couple that went well into the nines. He also restores old Pontiacs, including complete frame-off builds. He can do just about everything, including building the engine. If I had the money, he'd probably be all in on building a Stocker. Another Pontiac neighbor would also help. There are probably Pontiac friends all over the country who could get together on a Stocker project. Some of the Pontiac clubs probably have members who would enjoy a Stocker club project.
Our local track don't run Stock. So, we'd have to tow several hundred miles, to run 'em. Would have to be a dual purpose car, running mostly local bracket races, to justify having a Stocker.
There was a family in a nearby city with the last name Cardwell. They had several competitive cars, for years. Many of the older div 4 guys here will remember them. You can still find their name on some of the DRC race result lists. One brother's name was Ronnie, the other Doug.
The reason I mention them is because they built a '69 350HO Tempest, as a Stocker. Don't have a clue why( I think I'll ask 'em), since they were always Chevy guys. I have the dyno sheet showing that it made 434hp. Anyhow, after it was built, it didn't show enuff potential for them, only running mid 12's, before doing any serious tuning & tweaking. Had they known anything about Pontiacs, they would have chosen a better combo.
So, they sold it to a local Chevy bracket racer. He immediately wound it up too high & broke a stock rod. He had another short block built, & got it running, then put it up for sale, That's when I bought it, for $7k, in 2009.
Had 2 bracket cars. Bought a 7.3 diesel crew cab dually, & a 2-car gooseneck, & planned to race a lot at our local track, in 2010. But, our local track did not open at all in 2010. So I sold the truck & trailer. Sold the Tempest to my Pontiac neighbor, and sold my other bracket car as a roller. I assumed my local track was history, just as most of the other tracks we use to race are.
I began foolin around with a little dirt racing, at our local track. Then the drag strip opened back up. Kept running for a few years, so I decided to put another bracket car together. The neighbors helped & it would have been ready for the 2017 season. So, I bought a nice open car trailer & a used 2500 HD GMC, & was ready for 2017.
But, the 2 track owners had a fallin out, and the track was sold to a bank, at auction. No racing in 2017. So, I sold my '68 Bird as a roller. The track is on good river bottom land. So, I assumed it would be sold & farmed. Not so. One of the former owners bought it back, & resumed racing.
So, I bought an '80 Bird, & put my 455/TH400 in it. Hope to make a few passes this year. The only reason I'm telling all this is to let ya'll know a little more about me. I'm not some flake trying to impress a bunch of serious racers.
Below are some pics of the '69 Tempest, as it was when I bought it, then as it looked after my neighbor did a frame-off rebuild into a sort of a modified "ET" tribute car. For those who don't know, the ET was a prototype of a car that was never put into production. It is said to be the forerunner of the Judge. It was to be on a basic Tempest/Lemans body, and use a 350HO for power.
The 1st few paragraphs of this article tells the ET story.
https://silodrome.com/pontiac-gto-judge/
http://justacarguy.blogspot.com/2009...ontiac-et.html
Some here may remember the Don Turk car that was for sale, for $10,500, IIRC. That was a bargain, IMO. I think the new owner won a couple of div races with it last season. If I'd had the money, I'd have bought that car.
Anyhow, it don't have to cost a fortune to build a decent Pontiac powered Stocker. But, if you must pay to have all the work done, including $5k plus for body/paint work, then the price will obviously be high. As for the body, I figure there are still a few usable bodies for less than $5k. And if you can do all the body work, quite a bit less than $5k, will probably buy something usable. Guys here are always talkin about how Stock/SS guys should know how to work on there cars to make 'em faster. Well, I think most guys who don't have big bucks must have good car building skills, in order to build a Stocker for a reasonable price.
Hey, these are just my thoughts & opinions. And, as we all know, opinions differ.
Name:	'69 350HO Tempest Stocker.jpg
ID:	53684   Click image for larger version
Name:	'69 Tempest Rear.jpg
ID:	53685   Click image for larger version
ID:	53687   Click image for larger version
Old 02-02-2020, 09:27 PM   #5
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
there was a car Stephen Pontiac campaigned back in the day this would have been a D1 car 69 firebird 400 car , I know the person who has it ,, any one have any pictures?
Old 02-02-2020, 10:09 PM   #6
The sad fact is hardly anyone builds their own stuff anymore. Add to this that several good "brand name" builders won't touch a real Pontiac engine.
I had a 77 Bonneville roller for sale about 7-8 years ago. Rust free Ca. car. With a 400/260, it will run N/SA where it doesn't need a roll bar...Easy 1 second under car.
I had it for sale here for about 3 months. Never got the slightest nibble. Ended up scrapping it.
Another fact is , if you can afford to play the NHRA game, most people want to do it with a 10 second car. Win or lose, you get to do a big wheelie.
Ask again, what it costs to build a low 10 second Ram Air IV car . You'll have your answer why you don't see many Pontiac anymore.
Old 02-02-2020, 11:01 PM   #7
oldskool
oldskool's Avatar
Yeah, that Bonny would work. As most Pontiac guys know, Bob Michael built a '77 Catalina. And before that a '77 Lemans, which Dave Ribeiro has now.
Bruce Noland is building a '69 Bird. Don't know what engine he'll run. He may have said & I just don't remember. I do remember that he said it has the aftermarket block. so it's a serious build. Lookin forward to seeing how it does. It's been posted that John Schloe switched over to D-ports after he messed up a RAIV head. And we all know that Scott Burton sold his '70 RAIV, and it was shipped overseas.
"...several good "brand name" builders won't touch a real Pontiac engine..."
Apparently, Parsons & Myers will. And there are obviously several others, since there are still quite a few Pontiac Stockers & Super Stockers running.
While on that subject, I'll just go ahead & ask the question to all you forum guys. Besides Parsons & Myers, what good engine builders can & will work on Pontiac Stock/SS engines ?
Pretty sure there are several well known Pontiac engine builders, who can build the shortblock.
https://www.dcimotorsports.com/servi...ngine-builder/
I'll ask around & add others that can build Pontiac Stocker engines.
This shop built a 400 engine for East Coast GT SS racer Vic Santos. His car ran real good. so, they can probably also do a Stocker engine.
http://www.bouchersracing.com/racers/
Now, when it comes to the head tricks, like acid porting or whatever they're doin to heads these days, that might require a shop that sorta specializes in that type of work. I remember reading a section on the Heads-Up site, describing their procedure. But, that section was later deleted.
https://www.headsupcylinderheads.com/services2.html
Julie Biermann drives a quick '68 Bird Stocker, built by Tim Gillespie. It has a Heads-Up decal on it. See pic below.
There are several competitive Pontiac racers gettin 'em built somewhere. Just did a real quick check of my records. I have pics of more than 50 Pontiac Stockers that have raced this century. And, most of the cars are still racing. I realize there are thousands of other brand Stockers out there. But, if there were thousands of Pontiacs, there would really be no reason for this thread. Most all the Chevy combos have been beat to death for a LONG time, & most here know all about 'em. So, probably not too many guys would wanna hear it all again.
Old 02-02-2020, 10:40 PM   #8
oldskool
oldskool's Avatar
This it ?
Name:	Stephen C-S .jpg
Old 02-03-2020, 07:04 PM   #9
gmonde
gmonde's Avatar
This it ?
yep,, that's it thanks ! any other pictures please post
Old 02-03-2020, 04:07 AM   #10
oldskool
oldskool's Avatar
OK, I think I mentioned Ryan Warter's '75 Formy, & even posted a video of his win at the Northwest Nats.
The only '76 Bird Stocker I remember ever seeing belonged to Mike Morgan. He won the K/SA class with it, at the 2014 US Nats.
https://www.dragracecentral.com/DRCS...r2014#indextop
After that, Mike sold the car & bought the '77 350 powered SS Formy from Sal Piacentini.
Last I knew, the '76 Stocker belonged to Kevin Love.
To that car I'll add some '77 Bird Stockers I've known of, that have run this century. Don't know the history of most of 'em. I suspect that most have changed hands one or more times.
I'll start with 2 nat record holders. One belonged to Bill Edgeworth, the other to Dave Ribeiro. The next one belongs to Chad Smith. It's the former Paul Dilcher car.
The next 3 were driven by Tommy Pettigrew, Rob Holmes, & Mike Moyer.
The last one is driven by Dylan Biondo. It's been in the Biondo family for years. I know Sal & Peter drove it some.
We've talked about some of these cars. Maybe some of you guys can give us the history of some of 'em.
One thing I DO know. These cars, with the 400 engine have really taken a severe hit. I think it's really sorta overkill, to add 23 hp to an engine, just because it's in a Firebird body. Seems to make more common sense to factor the engine the same, no matter what body it's in. But, I've already said that. And I'm sure others have said the same about other brand engines.
Name:	Kevin Love .jpg
ID:	53693   Click image for larger version
Name:	Bill Edgeworth  NHRA record holder .jpg
ID:	53694   Click image for larger version
Name:	'77 Formy N-SA Record Holder.jpg
Name:	Chad Smith .jpg
ID:	53696   Click image for larger version
Name:	Paul Dilcher .jpg
ID:	53697   Click image for larger version
Name:	Tommy Pettigrew.jpg
Name:	Rob Holmes .jpg
ID:	53699   Click image for larger version
Name:	Mike Moyer .jpg
ID:	53700   Click image for larger version
Name:	Dylan Biondo  .jpg
