Old 02-27-2020, 08:26 AM   #1
Liked 10,898 Times in 2,255 Posts
Default Re: Dumbo The Flying Elephant
What a day, nothing worked that would repeat with the exception of gravity. The bright spot is; its a solid roller so I will not have to pull the head to install a solid lifter for checking valve lift.
I'll try something different today.
Old 03-05-2020, 09:34 AM   #2
Change filters, add oil, install engine and trans. One step closer.
Old 03-11-2020, 08:39 AM   #3
I finally got the above post done.
I had some good reasons why it took so long. A lingering cold, and a Grandpa. Its fun being at the granddaughters Basketball, soccer, and volleyball games. I know people outside the states of Kentucky and Indiana do not Capitalize the word Basketball. I'm not sure what the penalty is in Indiana, but here in Kentucky it's not a felony but darn close.
Old 03-14-2020, 08:11 AM   #4
I have drive train installed. I have different shaped bolts for engine mounts, and transmission mounts. Both had same size bolts, now head size and flange is different making it easier to assemble. Best thing about this installation is never having having to use the ill fitting CSR shield. I want to say more about CSR but I won't, you get the picture.
Old 03-14-2020, 10:31 AM   #5
340Cuda
Liked 805 Times in 341 Posts
Larry,
I apologize if I missed this earlier in this thread, but what did you use that fit better than the CSR.
I am not a big fan of CSR either.
Thanks,
Bill
Old 03-14-2020, 10:51 AM   #6
TCI shields and a BFH. It ain't easy or fun adjusting stuff to make it fit. I don't think the knot on my left thumb will ever go away, missed swing of a four lbs hammer.
Old 03-14-2020, 11:56 AM   #7
MR DERBY CITY
Liked 8,197 Times in 1,536 Posts
Larry, its a shame that DUMBO is all dressed up , with no place to go.... I followed your build very closely....
