Old 05-30-2020, 11:26 AM   #1
340Cuda
Liked 805 Times in 341 Posts
Default Re: Dumbo The Flying Elephant
Atlanta or Tulsa will depend on the weather. It will be a little farther to Tulsa from Ohio than Commerce Ga.
Yes but in Tulsa you don't have to drive through Atlanta!
Old 06-01-2020, 06:05 AM   #2
Liked 10,943 Times in 2,259 Posts
I have to fix engine before I go anywhere. I'm so tired of all this crap that is poorly made at a high cost. A loose cam basket on the cam gear what a pos. Thank goodness the FAST system would not allow it to restart after the run. The cam signal was lost.
Old 06-02-2020, 12:45 PM   #3
Dan Walcott
Liked 92 Times in 26 Posts
Larry I feel your pain, after 38 years running the same combination, refresh two engines and can't seem get more than 2 passes with out an issue. One had issues on the dyno and the other one just made it a pass and a half. Not sure weather to go fishing or gardening .
Dan Walcott is offline   Reply With Quote
Old 06-02-2020, 02:26 PM   #4
Frank Castros
Liked 2,766 Times in 978 Posts
A weed is a plant that has mastered every survival skill except for learning how to grow in rows.
If you’ve never experienced the joy of accomplishing more than you can imagine, plant a garden.
Old 06-05-2020, 01:41 PM   #5
MR DERBY CITY
Liked 8,216 Times in 1,537 Posts
How is Dumbo s recovery ?
Old 06-06-2020, 07:15 AM   #6
As the guy in NETWORK said "I'm made as hell and not going to take it any more! "
At best that is how I remember the quote.
I purchased a good idea part that is not in tolerance, poorly assembled, and supplied with the cheapest materials that fail in minutes.
Beware of a Rolon brand chain.
On a positive side I need to thank; Brad, Cooter, David, Jeff, Jimmy, Mike and Randy for some good honest help and direction. Thanks again.
Old 06-06-2020, 06:52 PM   #7
doglover44
doglover44's Avatar
Liked 497 Times in 234 Posts
When's Dumbos next flight outing ?
Jake Biermann
