Old 10-27-2020, 10:00 AM   #1
Robin Lawrence
Sponsor
Liked 715 Times in 120 Posts
Default Re: Not for Nuthin' But Close!
I have no idea ;-)
Well I have a little experience in this area. One option is what I mentioned earlier about a flashware product such as HP Tuners. Link to hardware. https://www.hptuners.com/mpvi2/
The hardware will set you back about 300 plus another 100 for the license to modify the file. Once that is done you can reflash or tune as many times as you wish. You will need a laptop computer also.
There are a ton of Stand Alone ECU's out there. Some are fairly powerful and others can be very simple. I can only speak for the Holley since it's what I do.
A Terminator X Holley (low cost system) can be had for about 1000 and includes the harness. Here is the issue, unless the 2.2 uses a common crank pattern like 4X on Crankshaft then you won't be able to trigger the ECU. As simple as your deal is I would work with the stock ECU. It is speed density and has a VE table. It's so very basic, just tune the VE table (fuel) and timing.
Robin
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 10-27-2020, 12:04 PM   #2
Billy Nees
Liked 7,782 Times in 1,743 Posts
Thanks Robin for your input. HP Tuners is the way that I have been leaning since I started this project. When you're dealing with an nonredeemable vehicle, cheap is good.
Billy Nees 1188 STK, SS
Old 10-28-2020, 08:58 AM   #3
Signman
Liked 269 Times in 99 Posts
This looks like great fun!
Love it!
There are plenty of cheap laptops out there. Check out Microcenter for refurbs. They usually have a few with small HD for 200-300 sometimes cheaper.
I have a good WIN XP laptop but think the HP Tuner Software wants a newer operating system. It's important to check what type of cable is included with HPT. If it's serial you either need an old laptop or a gender changer of the right type. If it's USB you should be good to go.
Old 10-28-2020, 12:30 PM   #4
Marty Knox
Liked 44 Times in 19 Posts
It looks like with HP tuners the Transmission Control Module program has to be bought as well. I am sure you will want to adjust the shift points.
Marty Knox 3071 STK
Marty Knox is offline   Reply With Quote
Old 10-28-2020, 04:58 PM   #5
Maybe , but these EFI combos have a definite torque curve , that seems to fall off rapidly.
With stock cams, I wouldn't up the shift points, without trying it manually first.
Old 10-28-2020, 10:10 PM   #6
Tom Meyer
Liked 354 Times in 120 Posts
We race a 2.2 eco in IMCA dirt track and have done a lot of wheel dyno work. We have picked up a lot of Hp on the curve with a change in the stock ecu tune. We have to run a stock exhaust manifold, but a header and pipe should make more power. Face book Garret at TBG tuned for your tune up he does a lot of eco stuff. PM me and I can tell you some stuff on these motors cheap. They can turn 8000 on the stock bottom end with the rev limit turn up. The intake is the cork like many other engines. If you pull the intake off clean it out good with carb cleaner along with the intake port and valves will help with air flow. A fresh air system is also worth some power if done rite. The stock injectors are fine. Don't forget to change the fuel filter and copper core spark plugs with the gap run a little tighter will also help. Go to a junk yard and get stock cams from a Malibu or Classic same lift but different grind for more toque. I got some for 20 dollars for the pair. Get rid of the balance shafts and it will spin up quicker. There is a simple kit for this that can be done rite in the car. We have made around 160 at the wheel with this combo and with a header it would be more. We run a stick and used a Saturn Vue final drive, it has more ratio 3.94 to a 4.41. Have not done a lot of auto stuff but I sure a master as yourself can find out more. I would like to do a car like this but can't get done what I have already. Tom
Tom Meyer 5240 SS Stock ???
