#181 | |
Liked 319 Times in 82 Posts
That bar is actually part of the frame connectors. I’m sure it’s completely overboard but I set out to make the chassis stiff as possible. |
#182 |
What about making a rear driveshaft loop off of that bar?
Very nice build by the way sir.
Keith A/S 2990/Terri A/SA 2991 "Imagine what you'd attempt, if you knew you could not fail!" |
#183 |
#184 |
Liked 10,803 Times in 2,244 Posts
I never thought about connecting the frames left to right. But there is a bunch of stuff that I’m not smart enough to think of. A cage got ours stiff. I may have to make something and see if it helps. Thanks for sharing
#185 |
Got the 2nd set of lowering blocks installed today. While I was down there I decided to check on the drive shaft vs fuel lines and thankfully this is close as it gets.
![]() Here is a picture of frame connectors. I did get the ok from D1 tech on this. I still have mix feelings about it. It’s definitely overkill and way heavier than I expected. I do like how the drive shaft loop is part of it. Maybe down the road I’ll have one fabricated from CM to loose some weight. ![]() |
#186 |
Today I got the car on the scales....looks like I can make A... I’ve got some options to move weight around but what do you think??
#187 |
Is that with you in it? Can’t wait to see it run!
Joe Martens AA/Stock 3969 |
#188 |
#189 |
Very nice build, I also cannot wait to see it run.
#190 |
Liked 237 Times in 126 Posts
I have a chassis stiffener like yours on my '68 Mustang. Definitely tightens up the frame. Mine is from Total Control, a part of Chris Alston's ChassisWorks. Where did you get your unit?
