Old 04-03-2008, 10:37 AM   #1
Hnasko Racing
Default Re: Questions w/ running Alcohol?
Thanks Steve for some input.
What is top lube? Is that in the fuel mix? Or something you have to add?
Is it cheaper to run a dragster on alky or race fuel?
Also on most dragsters in 8 second range on alky how much fuel could they burn in one pass?
How long do you think a drum would last pass wise?
How often do you have to change the oil when running alky? or plugs?
It would prob be a 460 bbc.
Hnasko Racing is offline   Reply With Quote
