Old 03-14-2022, 12:28 PM   #141
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
Originally Posted by Keith 944 View Post
Looking great! Question, what is the quick pin in the parachute mount for?? Will you be ready for the first outlaw race in April? I can’t wait to see it. Hope you don’t mind if I come over and ask you a billion questions. I do plan on running up to Pennsylvania and use the same powder coat place that you did. thanks for the pictures and all the info
Hey Keith, the quick pin is for a push bar attachment. I also have a tow loop under the front, depending on how I choose to move the car.
No, the car won’t be ready for the April race. Summer at the soonest now. The next big project is to wire the car and I need to give it 2 to 3 months. I’ve done a fair amount of wiring, but haven’t tried a from scratch EFI harness, so I wanna take my time to try and avoid any mistakes.
Todd Geisler is offline   Reply With Quote
Old 03-19-2022, 08:12 PM   #142
Todd Geisler
Safe place to store the front end so I can work on the car.
Old 03-27-2022, 09:11 AM   #143
Todd Geisler
Been putting it off being a PITA, but got the fire system 90% plumbed...all 1/4" stainless hard line. Just have to mount the nozzles once a couple more fittings come in.
Old 03-27-2022, 09:15 AM   #144
Todd Geisler
Last weekend I spent some time building a new wishbone, delay box mount and some other small brackets so I could deliver them to powder coating and anodizing.
Old 03-27-2022, 08:07 PM   #145
TOSTO RACING
TOSTO RACING's Avatar
Liked 663 Times in 187 Posts
Beautiful!!
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
Old 04-01-2022, 09:28 AM   #146
Todd Geisler
Some more progress this week. Powder coating and anodizing came back.
Inside fire nozzle centered above the transmission.
Switzter Dynamics fuel rails anodized very nicely.
Custom switch mount, MAC valve mount and delay box mount on the shifter.
Custom pinion sensor mount, Davis Technologies sensor & ring.
Wishbone mounted.
Upper fender mounts anodized.
Hatch hinge/roof supports.
Tim McAmis light weight fuel cell cap anodized.
Old 04-01-2022, 09:32 AM   #147
Todd Geisler
Preparing to start wiring here soon. The plan is to start in the back and work my way forward. Needed to mock up the shock sensors to wire them, but the shock simulator blocked them from bolting up forcing me to mock up the shocks temporarily. Simulator goes back on as soon as the rear wiring is complete.
Old 04-01-2022, 11:49 AM   #148
FED 387
Liked 335 Times in 182 Posts
ABSOLUTELY GORGEOUS AND FLAWLESS WORKMANSHIP--- I envy you---FED 387
Old 04-13-2022, 02:07 PM   #149
Todd Geisler
Small update on the most recent progress. First off was to prepare to bond the roof supports to the cage. This required stripping the powder coat off to bare metal, yet not damage the powder coat outside of the bond area. Alot harder than it should have been because like a dummy I put the tubs in the car and my access to reach the area was gone now. Had to reach from outside the car making it quite challenging.
Old 04-13-2022, 02:16 PM   #150
Todd Geisler
Next up was to finish up the parachute. The old chute bag was badly sun faded so I got a new replacement. The aluminum spring can was pretty beat up from the crash so I straightened it as best as I could then had it powder coated in an effort to save it. Lastly, a new chute cable installed.
The last few things were to install new door lock cylinders then sandblasting the trunk latch & hardware then installing as well as the trunk lock cylinder.
