Old 06-03-2023, 08:47 AM   #1
Liked 11,032 Times in 2,267 Posts
Default Re: Dumbo The Flying Elephant
Do I have a lot to learn and master. Master is used in the loosest terms. I think I needs lots of dyno time and a dyno mule.
Thank to all trying to help get into FI
Old 06-03-2023, 10:33 AM   #2
Signman
Liked 269 Times in 99 Posts
When closed loop the system will work to attain those AF values notice the % of change and edit the fuel table or let the system self adjust. Be sure to save each tune after changes are made.
Old 06-03-2023, 06:28 PM   #3
I disagree I built the engine also. Robin Lawrence’s dyno service help me more than I know I think it’s in closed loop and corrects very little. Plugs and pipes look good.
They just called us to the lanes.
Old 06-04-2023, 11:40 AM   #4
Signman
Seems you have some of the best help available to anyone in the country.
Old 06-04-2023, 03:31 PM   #5
I know I’m getting better. I’m just not getting better fast enough to gain confidence and be able to evaluate some of the things I would like to find out about. Things like individual cylinder timing, torsional twist of the crank and how to tune for it, timing injection pulse to reduce to reduce energy in the reversion wave in the intake. And all of these things may help or hurt but it would be nice to know.
Old 06-05-2023, 09:38 AM   #6
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Larry, I know you want to know everything right now and don't take this the wrong way. I have been in your shoes and had the same thoughts and wanted to know everything all at once. But you are a smarter man than I and I know you will grab all this in time.. Go easy on yourself and take what your mind can absorb and remember.. Just make sure you do save EVERY change you make. This way you can back up to a stage where you know where you are and start from there.. You will get this!!!! I have complete confidence in you.. It's like the old saying "old dogs learn new tricks at a slower rate"... I can say this because I have been down the same road... But , I learned enough to be confident, and it just takes making changes and putting the car down the track or another dyno pull..
Don't beat yourself up... You WILL get this in due time I promise!!!!!
Mack Reeves
2377 STOCK & SUPER STOCK
Old 06-09-2023, 07:38 AM   #7
To help avoid confusion on what file needs to be downloaded to see the data log of the run. I will delete the down loadable files from the ECU so only to have a choice of around eight to download for the run. Every time I stated the engine it starts a new file.
