Old 01-30-2024, 09:53 AM   #1
Liked 10,714 Times in 2,230 Posts
Default Re: Dumbo The Flying Elephant
The loner test fit head got here Friday but being a grandparent was way more important than working on the elephant this past weekend.
Old 01-30-2024, 08:51 PM   #2
Sometimes you stumble upon a deal. Case in point is the PRI show a few years ago. Pac had a show special on the spring height micrometers I bought all four they had and today I used the real small ones and they are very accurate. It was a case of nothing else would work besides snap gages. And I hate snap gages. Thank you PA C
Old 01-31-2024, 09:49 AM   #3
I have to make an adapter to keep the mic centered on the valve stem. Plus I have the added fun of checking with top locks, standard locks, -.050 locks, and +.050 locks to get the best setup for the head. Man I love this game!! It’s all worth it when the light come on in our lane in a heads -up race, and when it doesn’t I have a new roadmap to follow and guide me.
Old 02-01-2024, 09:00 PM   #4
I finally got the stuff made and was able to figure installed height. The kool part is I was instructed to get several different sets of valve locks. The standard, the +.050, the -.050, and the top lock. It moves the installed height around and with the help of shims I will be able to get to my coil bind target number on each spring. I’m hoping to get to size to plus .005” on installation height.
A tip of the Hat to all of the cylinder head folks, it’s not easy just to get the installed height correct, past Tech, and run hard all the way to the Finnish line. The real good cylinder head people are a bargain.
Last edited by Larry Hill; 02-05-2024 at 07:56 PM. Reason: Billy was having to much fun!
Old 02-04-2024, 08:53 AM   #5
I’m getting to use my Christmas present from Patsy. It’s a plastic tray from Summit that holds all of the valve train parts in each cylinder’s location.
Old 02-04-2024, 09:55 AM   #6
Billy Nees
Liked 7,742 Times in 1,740 Posts
The real good head people are a bargain.
Larry, you are talking CYLINDER head people right?
Billy Nees 1188 STK, SS
Old 02-05-2024, 07:55 PM   #7
Thanks Billy. I think a little quicker than I type. I will change it.
Old 02-15-2024, 11:30 AM   #8
Once I got the heads mocked up now waiting on parts. We had to withdraw from Florida.
Old 04-17-2024, 11:02 AM   #9
Rick J
Liked 73 Times in 37 Posts
FYI, avoid +.050 locks if you can, if not use 10° locks & retainers.
Reason is locks only clamp on the valve stem below the groove, the ID of the lock is larger above the groove.
Rick J is offline   Reply With Quote
Old 04-19-2024, 10:45 AM   #10
Thanks I will check that.
Spoke with someone that had some thoughts on why the head leaked coolant in to the spark plug bore. Coolant casting core flotation. I wonder why it took two seasons of racing to appear on this head an only one season to cause a problem on the odd cylinder head. One of life’s little mysteries.
