Old 03-08-2024, 12:25 PM   #1
Doug Hoven
Liked 828 Times in 163 Posts
Default Re: '70 Nova V/SA to F/SA Makeover
What made you wanna change from V/SA to F/SA ?
I sort of got bored of it after a while. After driving a few 10 second cars I got the "bug" to go fast. I sort of ran out of patience for the 6 cylinder. I threw everything that I could, almost the kitchen sink, well in this case, the toolbox, and nothing I did really made the car any faster than it was when it was last ran 10+ years prior. Solid lifters, more modern camshaft grind, roller rockers, radial tires, 7in. converter(yea that definitely didn't work). The only thing I achieved that made the car faster was getting some "welfare" from the good people at NHRA. With my "improvements" I managed to run the best mph the car owner had ever seen by a decent margin, but my cam killed the 60ft, so it ended up being no better for ET. One thing I would've liked to try was a 3 speed over the power glide that was in the car. The 2.74 low may have helped gain back the 60ft I lost with my "big" cam. It may find it's way back into the car some day for laughs, but not right now. Would only take a rear tire change and changing around a few wires.
1189 F/SA
Defunzalo Racing Enterprises
Old 04-01-2024, 04:49 PM   #2
Doug Hoven
Well I've made some headway over the past few weeks. Decided to spend my spring break from school working on my engine. Had some pretty late nights and early mornings, but it got done. In the end, I got it together, it sounded good on the "ear dyno," and ran decent on the engine dyno. I spent the entirety of my Saturday this past weekend "spiffing up" the drum brakes on the car. I was luckily able to find a poor soul about 5 minutes from me, up the road from ETown, that was able to cut my drums for me on short notice. Also taught myself the long lost art of rebuilding a wheel cylinder when one was a little weepy, and couldn't get a new one that day. However, the local Autozone did have a rebuild kit, as well as a reasonably priced wheel cylinder/master cylinder hone. I then spent my Easter morning wiring in a new fuse block to replace the "old school" glass fuses as well as creating a combination water pump/fan switch with a double pole switch and a diode. Hopefully by the end of next weekend I will have a running and driving car and can test all of my new(well some only new to me) parts on the "E.T. dyno."
1189 F/SA
Old 09-03-2024, 07:43 PM   #3
Doug Hoven
Well it's been a while since I've added anything to this thread. I've more or less just been racing the car the way it was all season. In the middle of changing my transmission pan for a more purpose built piece, I ended up finding a piece of metal in the bottom of the pan. After getting much more up close and personal with a th200 than I ever had before, we found that it was a piece of the rod that actuates the parking pawl. The rest of the trans showed to be pretty worn, so I also discovered the not so easy task of sourcing th200 clutches and steels. With some luck, I sourced the parts, and the transmission went back together about a week later. The torque converter I've been running that has worked fairly well is a Dynamic that was built in the early 2000s for a 305 stocker. I had the stator changed midway through the season which has improved my 60ft times a bit. My most recent upgrade that I actually documented was changing over the front drums on the car to a good used set of wilwood front discs. An upgrade in another part of my racing "crew" meant that I ended up with these brakes. Was a very straight forward job, and with the addition of a residual pressure valve for the rear drums, I'm in business. Hoping to get out this weekend for the Mid-Atlantic S/SS series to test out my new brakes.
Name:	Drum Brakes.jpg
ID:	71130   Click image for larger version
Name:	Disc Brakes.jpg
1189 F/SA
Old 09-04-2024, 07:37 AM   #4
Billy Nees
Liked 7,688 Times in 1,732 Posts
Don't "lose" those original 6 cyl. drums!
Billy Nees 1188 STK, SS
Old 09-04-2024, 11:51 AM   #5
Doug Hoven
Don?t worry, they?re safe and dry. OBTW, for inquiring minds, the weight savings was 8lb per side. And these are not the super lightweight brakes. They are definitely lighter than a stock rotor, but are still finned.
1189 F/SA
Old 09-23-2024, 03:06 PM   #6
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Any "news" to share or results from this season ?
Old 09-24-2024, 05:50 PM   #7
Doug Hoven
Well, I've had some ups and downs this season. For the most part, the car has been great. Apart from maybe one or two runs, the car has followed my ET predictions really well. As a driver I've sort of just been all over the place this season. But, for it only being my 3rd full season of racing, I can't be too unhappy with how I've been doing. I've definitely made some progress in my E.T.'s this season compared to last year. My best ET in NHRA competition this year has been 11.21, knocking on the .65 under mark. The timing of the Dutch classic this year could be a recipe for some fast runs. I'm pretty pleased with how the car has been running. I am aware of a handful of things that are making my car "slow," but for now, my budget has determined where I've spent my money with this project. The front discs haven't shown me any ET so far, but the car is much nicer to stage, and more importantly it stops much better than before.
1189 F/SA
