Old 05-08-2024, 11:33 AM   #11
Steve Grady
Steve Grady's Avatar
Liked 132 Times in 44 Posts
Default Re: Head & Neck Restraint Rule
The neck collar was for fire safety, Not for neck support. That is why you now have to run a head sock or helmet skirt with the head and neck restraint.
Originally Posted by SGSST109E View Post
Once I read the differences between the neck collar that does nothing and the Hans type restraint. I was convinced two years ago to get one. It only took a few passes to be able to get everything off on my drive back on the return road.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 05-08-2024, 06:48 PM   #12
SGSST109E
Liked 126 Times in 61 Posts
Correct
SGSST109E is offline   Reply With Quote
Old 05-09-2024, 09:53 AM   #13
voltdr
Liked 100 Times in 51 Posts
I've been using a HANS type device long enough to have to have it recertified. I bought mine after I watch a friend roll his SC car when the center broke in his rear wheel. After talking to him a few days later, he told me his neck wasn't even sore after the crash. I really like how it spreads the load of the seat belts across my shoulder area and not just where the belts ride.
When I first got it, it took a little extra time to get everything hooked up. Now it's easy-peasy. I remember when I made to switch to an open wheeled car, I thought the arm restraints were going to be too restrictive also. That is definitely not the case.
Dan
SC4698
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 06-03-2024, 10:16 PM   #14
gnicholson
Liked 4 Times in 3 Posts
Originally Posted by Lenny5160_v2 View Post
My routine has actually been to leave the Necksgen connected to my helmet at all times. So far it has seemed to simplify the process.
Nothing to do with this thread but Tony you were kind of hard on me yesterday in earleville.
gnicholson is offline   Reply With Quote
Old 06-04-2024, 12:26 PM   #15
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 225 Times in 96 Posts
That was a great race, Gary! Keep making that pass and things will go well!
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 06-15-2024, 02:31 PM   #16
Charlie Yannetti
Liked 192 Times in 83 Posts
After wearing a HANS during the Cecil County race, and finding it to be a great distraction, I switched to the Simpson Hybrid for the Maple Grove race, and found it to be an instant night and day difference.. I also went with a helmet skirt, but found that it doesn't seem to allow enough fresh air into the helmet, which resulted in glasses and visor fogging.. I'll be switching to a head sock for the next race..
Stay tuned for further hunt and peck results..
The HANS will now be living in the RV, should anyone need one at a race I'm attending..
Charlie Yannetti is offline   Reply With Quote
Old 06-15-2024, 08:03 PM   #17
Keith 944
Keith 944's Avatar
I need to try that one Like you said the one I was using flat out sucks. I don?t have a neck anyway, so it seems to ride the helmet and gets snagged sometimes. Definitely felt unsafe wearing it in the very tight confines of the Porsche so I just picked a spot to dump and kept it just under 150 so I didn?t have to use it. Same one in the Alfa isn?t as bad because I have more room. But would still like to see the difference in them.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-16-2024, 11:51 AM   #18
Charlie Yannetti
YUP KEITH!!.. experienced the same problems in the roadster.. felt like someone was tapping on the back on my helmet during staging.. UGH.. problem now solved..
