Old 07-31-2024, 09:35 PM   #1
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Dumbo The Flying Elephant
A tip of the hat to Mahle Pistons. I checked the next size +.005" over pistons for the engine and size varied .0003" and weight of the eight pistons varied by less than a gram. I forgot to check weight of small piston to larger piston for balance. The bores checked OK just not very straight. With us going to the next size Jeff Taylor Performance will have it round and straight. Honing
using a Profilometer assures the values of RVK and RPK are closely observed. New equipment is always plus for any shop.
Hi Larry, would you be willing to share the RK, RPK and RVK you got on average as well as the oil ring pull tension.
Paul Precht is online now   Reply With Quote
Old 08-01-2024, 07:50 AM   #2
Liked 10,756 Times in 2,236 Posts
Paul I’m not trying to be evasive but that information is with Jeff Taylor Performance in Sellersburg In. Some things I prefer not to know. The reason being, if I don't know some proprietary information and for some reason it gets known it could not come from me.
On ring pull are you curious about RB or Gen 3?
Meanwhile, back at the ranch, I believe all the parts are here. It’s all on me now.
Old 08-01-2024, 03:14 PM   #3
Paul Precht
Paul I?m not trying to be evasive but that information is with Jeff Taylor Performance in Sellersburg In. Some things I prefer not to know. The reason being, if I don't know some proprietary information and for some reason it gets known it could not come from me.
Meanwhile, back at the ranch, I believe all the parts are here. It?s all on me now.
Thanks for the reply Larry, both the RB and Gen 3 if you're willing to share but the RB being 3/16ths is what's in most of my builds so it's interesting to see what is working for other people as I'm a bit shy about going too light. Back in the day Hastings used the old TRW style black expanders and I could grind one end to give me the tension I wanted, I recently mixed a standard tension Speed Pro expander with Hastings rails as they had a shorter radial wall which is going in a low budget 383 for my bracket 62 Dart. I target the middle of Total Seal's specs for RK, RPK and RVK and it's a bit tricky getting there and like with oil ring tension, it's interesting to see what's working for others.
Old 08-02-2024, 07:56 AM   #4
Best I can remember for the RB is using an old fish scale that had a needle it was about 10 to 12 lbs. Once something worked I would reuse the the oil ring in the next setup. The Gen three stuff I haven?t had much success on oil control. I?m trying something different this build.
Old 08-03-2024, 05:47 AM   #5
I got to use a Buxton valve spring checker, Wow was it nice. A read out in thousands of an inch and lbs of force and a printout of each spring. Put in coil bind clearance and valve lash and it shows installed height. A really nice tool and it?s easy to use.
It?s almost 5:00 am so I better get to work.
Old 08-03-2024, 08:11 AM   #6
Frank Castros
Early birds get the Wally.
Old 08-03-2024, 03:57 PM   #7
Taking a break. The block had its final cleaning. Cam bearings are installed. Sound track from "The Rocky Horror Picture Show " is playing, all is good! Solvent tank cleaned and refilled with fresh solvent. Supper tonight at the Fancy Farm picnic, where everything is home made and all proceeds go to the church.
Back to work
New cam turns in the bearings, another good day of racing.
