#21 | |
Liked 398 Times in 157 Posts
I like oven cleaner, just don't get it on any painted surface!!
Jim Miller 103 U/SA |
#22 |
Liked 29 Times in 5 Posts
An ultrasonic cleaner works really good for us. We do several sets of LS and LT heads every day.
SS/AM 2917 |
#23 |
Liked 19 Times in 4 Posts
Does anyone have a contact for a shop with a Ultrasonic cleaner in the Phoenix area?
These heads are 22x12x8 inches Thanks, Brad |
#24 |
Liked 308 Times in 103 Posts
Something no one has mentioned.. You can put them in the dishwasher if you are single or brave or stupid LOL
We have ran Cascade in our jet spray(hot tank) in a pinch.. 5 boxes to 80 gallons of water, works great. I'm sure you could probably mix in hot water and scrub heads with it Mike Taylor 3601 |
#25 | |
What is the typical size of Ultrasonic Cleaners used for cylinder heads? Thanks, Brad Last edited by bpete; 01-31-2025 at 12:20 PM. Reason: updated info |
#26 |
Liked 8 Times in 5 Posts
I switched over a blast cabinet to Baking soda and its the best. Does a great job on carbs also then just wash i hot water and it all dissolves. You don't have to worry about any media hiding and coming loose and crashing an engine.
John Donato Stk / SS 3435 |
#27 |
Liked 16 Times in 11 Posts
Soak in simple green works for me.
#28 |
Liked 10,779 Times in 2,240 Posts
A big thanks to everyone that offered a workable solution!
#29 |
Liked 120 Times in 53 Posts
Soak in a mix of oxy-clean and water, softens and loosens that carbon in a few hours. Good trick. Did not discolor the aluminum at all.
Wife saw me cleaning the ring grooves on used pistons and recommended it. |
#30 |
Liked 693 Times in 201 Posts
Anyone try the dry ice method popular on the you tube channels?
Mike 7570 A/SA |
