#41 |
Liked 274 Times in 105 Posts
Jake, local, top bulb brackets.
#42 |
A fine Monday afternoon to all. Be sure to notice the 5 - 7 crossfire enhancement.
#43 |
Liked 2,716 Times in 956 Posts
Very clever build, I love it!
#44 |
Custom home built column
#45 |
The Square 10 will be the most bare bones, stripped down piece I have ever built. The interior will have a steering wheel, shifter, and seat. No dash, no carpet, no mat, maybe a couple of the 3M anti-slip pieces. I expect it to weigh around 2850 with driver.
#46 |
Liked 385 Times in 150 Posts
Truck looks awesome, I do have some concerns/points I would like to add.
1) 5-7 swap works great but I think the wire you are using is too short, don't be fooled into thinking shorter wire between the two plugs will enhance the spark. (unless you already gapped it over the .125 minimum) 2) I tried the cable tie trick and while it will work, change to white ones as they hold the heat better. (I've never tried adjusting from outside, I'll assume this is with the engine off??) LOL, Love the build, cool truck!
Jim Miller 103 U/SA |
#47 |
Thank you. I need more tech help in my mature years, so I appreciate it.
#49 |
I have some exciting news. I have sold my home, relocated, and am beginning construction of a new shop. Stand by for more information.
#50 |
Roughing in some wiring and components
