Old 07-27-2025, 08:30 AM   #1171
Liked 10,756 Times in 2,236 Posts
Default Re: Dumbo The Flying Elephant
It was a new converter that may have had the tolerance stack line up the wrong way. It happens sometimes.
Like a big crank, to the plus side of the tolerance, a housing bore to the tight side of tolerance and a bearing shell that is on the small side resulting in an unacceptable clearance problem.
I am trying to correct a few perceived future problems.
Old 07-29-2025, 02:24 PM   #1172
Yesterday after supper the house A/C died. We slept in a house that was 83 to 84 degrees. We just got it running. The start capacitor died. Installed a new one and has lowered the temperature one degree in 90 minutes. Heat index is close to 115*
Old 07-29-2025, 04:03 PM   #1173
FED 387
Liked 333 Times in 180 Posts
try to Stay cool and be safe--- don't do anything stupid--- drink lots of water----if you sweat a lot take salt tablets too---FED 387
Old 07-30-2025, 08:16 AM   #1174
Back after it today. Good start to the day I found my scale notes. When I started we weighed the car with me in it with all my stuff on and recorded all the numbers at each wheel. I then started adding weights in the seat and floor to mimic me in the seat and duplicate the scale weights. That comes a little later we still have ton of wires to connect.
Old 08-05-2025, 08:36 AM   #1175
Connecting the wires is easy, it is supporting them and keeping them off of the headers is the challenging part. We are getting there making brackets and such.
Old 08-05-2025, 06:12 PM   #1176
My hands and lower arms looks like I have been fighting with cats and losing. Hope to be at BG next week to race and test.
Old 08-07-2025, 02:07 PM   #1177
Frank B.
Liked 51 Times in 25 Posts
Are you still running FS or did you convert Dumbo to regular stock class?
Frank B. is offline   Reply With Quote
Old 08-08-2025, 08:32 AM   #1178
FS/D I am way to deep in to it to change now but I have the 6.1 DP that came with the car and a replacement 09 street engine and a 15 6.4 street engine just in case.
I had to get more tie raps and band aids. I am about to believe that no matter how many times you route and re route sensor wires it is never what you are satisfied with.
I am hopeful that I can get the car on the scales this weekend.
Old 08-09-2025, 08:57 AM   #1179
Frank Castros
Dumbo is obviously not a joy to work on.
Old 08-09-2025, 08:09 PM   #1180
Part of the problem is me and my size.
