Old 09-08-2025, 01:18 PM   #1
WKCOOK
Liked 5 Times in 5 Posts
Default Rim screws to eliminate slick/ rim slip
Is there a resource or rule of thumb to DYI drilling and screwing rims to slicks? Slicks spinning on rims. moving about 1/4"-3/8" ea. pass.
28.5X10" M/T slick.
88 Mustang
533 BBF N/A
WKCOOK is offline   Reply With Quote
Old 09-08-2025, 02:45 PM   #2
Robin Lawrence
Sponsor
Liked 717 Times in 121 Posts
Default Re: Rim screws to eliminate slick/ rim slip
I have used this guide,
https://quartermax.com/rim-screw-template-for-15-wheel/
STK 308
SS 3088
Robin Lawrence is offline   Reply With Quote
Old 09-08-2025, 10:06 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
before you drill the rims ,you might want to try an old Stock /Super stock trick.
Break the beads and spray the rim beads and tire beads with AquaNet hair spray. let it get tacky and reinflate the tires . you might get a small movement on the first hit ,but they usually stick after that.
Old 09-09-2025, 11:19 AM   #4
WKCOOK
Thanks guys.
we'll start with the hairspray and progress from there.
88 Mustang
533 BBF N/A
Old 09-11-2025, 09:18 AM   #5
Run to Rund
Liked 56 Times in 29 Posts
I blast the bead areas of the wheels with aluminum oxide media, then install the tires dry.
Old 09-11-2025, 06:48 PM   #6
WKCOOK
We're going with rims screws. We are leaving off two step @ 3600RPM. Want to leave at 4000RPM. Also late in season to break beads on the hope hair spray works. FYI have you looked at the price of aquanet? Lol.
88 Mustang
533 BBF N/A
Old 09-11-2025, 08:01 PM   #7
cordoba13
cordoba13's Avatar
Liked 14 Times in 9 Posts
4000 lb car 1.77 60 ft, 9" slick. 3M weatherstrip adhesive, no screws, no slippage, pulls lt/frt tire
cordoba13 is offline   Reply With Quote
Old 09-15-2025, 10:59 AM   #8
Dave Siltman
Dave Siltman's Avatar
Liked 68 Times in 25 Posts
I use Permatex Hi-Tack cement on 29.5x9 M/T and chrome Cragar SS. 3800lb. stick car leaving at 5500. Coat the tire bead, then the wheel, let it tack up and repeat then mount. Messy but works like a champ and cleans up easy with lacquer thinner.
Dave Siltman is online now   Reply With Quote
