Carlos - if all the mechanical remedies check out and it still happens, we have also found that when you go to get on full throttle AT THE SAME TIME as hitting transbrake, you will roll! Make sure transbrake is engaged BEFORE getting on full throttle. This one doesn't cost any money!!!
Good luck!!!!
Lynn Hoosigian 1828 SST, SG, SC |
LOL
THANKS LYNN i've done that one to, that one usually sends me out of the beams and well on my way for about 4 ft until i slam on the brakes, look up at the starter and ask for a "do over". usually he just points in the big end direction of the track and directs me to keep on moving.
S/ST 1739 Carlos Mendes |
Liked 880 Times in 311 Posts
It is correct the band adjust has nothing to do with rolling forward. It is in full apply when going forward. What are you going to do, loosen(adjust) it so it slips? ;~) The problem is the low band is applied & it takes toooo long for the rev clutch pack to tighten up & lock the tranny in low & rev. Pull the pan and check the clearance in the rev clutch pack. That can be done by inserting feeler gauges through the small square hole below the Rev clutch pack. (have to remove VB to see) Let us know how many thousands it takes to wedge the pack tightly. I suspect you have a tranny that may still have too small a supply hole. (Had known builder do that to me way back before I started doing my own) The stock feed hole is about .060. Should go to at least 5/16 or 3/8 for good fluid flow. That is if your VB is the type using single feed. Some have a feed & dump, dual...More holes to drill... Or you could have the wavy steel still in the clutch pack or you could have low pressure or you could have too much clutch pack clearance. It isn't going to fix it's self. You need to do some checking before just pulling it out. Did you check the pressure on the rev pack when you hit the T brake? You can also
air check the rev clutch pack, just like you can air check the low band when the VB is out. (not through the same fluid port, though. Did you do the tranny yourself or is it a well used unit from someone else? Hope this helps.
Adger Smith (Former SS) Last edited by Adger Smith; 07-16-2008 at 12:20 AM. Reason: sp |
wow !!!!!!!!!!!
adger i felt like i was still in some navy school and reading and reading your post over again. and feeling like i'm not getting it. i understand what you say but unfortunally i can geographyly figure out how to check it myself. in simple terms, i was lost after pulling the pan. even with the best instructions i would "F" that up. no i didn't do my own trans dynamic trans and converters did mine, i have about 19 runs on this trans. so i hope they warranty the darn thing. i have no complaints on there work. hell, who knows maybe its something i did. low on fluid, didn't adjust the low band after my first 2 runs. (was more like 10 before i made the adjustment). just don't really know. in this area i'm out of my element. all i can do is check the fluid come friday. at first i was hoping that it would be low and thus an explaination. but, it doesn't sound like you think so. got this sucks, since its in a full body car with the CSI cover over it and bolted to the engine with allen heads. **** i can't get a wreench on them so the entire engine and trans would have to come out....... my reallity truely sucks right now. i just love sportsman racing....... you know, life was alot easyier when the car went 12 something on the foot brake. as i have already said to my wife. the next time something happens thats where i'm going. i just didn't think it would be this soon. the world around us is just so expensive, who really has the money. thanks for everybodiest help. i'm going to forget about this today and go golfing on TOYOTA'S (my boss) nickael. friday will be here soon enough.
Carlos,
Good for you, admitting that you are lost and giving some good information. The last thing I want a customer to do is get in over his head trying to fix something. I'm sure Frank at Dynamic feels the same as I do. So it made atleast 19 runs & strated giving trouble. I would think something went away. Could be as simple as lip seals nicked or cut on assy. Send it back to Dynamic. They know their product & can probably fix it. You need to do that before you or someone else screws up more. I know I would appreciate a customer that was having problems deal with me to get them corrected. Get rid of those allens, they are case eaters... Put a "footed" style bolt with a clearance shank on there. Ask about any updates when you return the tranny. Good Luck, esp with that white ball.... :~)
Adger Smith (Former SS) |
thanks for your help alger.
the little white ball won again. i like playing, but don't love it, its good for me to show my face at these things. besides all the food and drinks were free, so i had a great time. today its back to the grind in this 92 degree weather in jersey. no problem for me i've got southern experiece...lol.. lived in charleston sc for 12 years and 7 yrs in jacksonville florida during my nanvy days. but, we don't live there anymore. in new jersey they stay home when it gets this hot. i'll call shawn at dynamic sometime today or tomorrow (my day off) and see what he thinks. in any case i think i have alot of work ahead of me. where's the million dolaar sponce and the pt crew when you need them. oh, i don't have one of them. so its me and me alone. this is going to suck
