Old 01-09-2009, 04:04 PM   #13
STAR Hg
Default Re: Vacumm Pump
A defective vane would have come apart during initial factory testing. We test all new pumps at approximately 200% of a typical drag race duty cycle application, its one of the reasons we do it. If a vacuum pump vane does break its almost always due to something getting into the pump, other than liquid or air, that does not belong in there. The most common culprit we find is a piece of valve spring material. The foreign object breaks the first vane then these broken pieces break the remaining vanes. Its a domino effect. All vacuum pumps are vulnerable to this situation.
An appropriate filter between the engine and the pump would completely eliminate this possibility. You use an oil filter and air cleaner to protect your engine, why not do the same for your vacuum pump? If a needle bearing from a broken rocker arm locks up your oil pump is it the oil pumps fault? Certainly not!
Remember, you don't get filet mignon for the price of chicken. And if everyone bought strictly on price we would all be driving Yugos, and they would still be in business.
Steve Fackett
STAR Hg is offline   Reply With Quote
