Old 12-10-2008, 12:55 PM   #1
leon philpot
Liked 2 Times in 2 Posts
Default 8.90 hp
can anyone tell me how many hp it takes to run 8.70's or so in a 2000 lb. dragster.
thanks in advance for any info.
leon philpot is offline   Reply With Quote
Old 12-10-2008, 03:36 PM   #2
R&S Motorsports
Default Re: 8.90 hp
Roughly about 500-550 HP when I first started racing years ago I had a 1800 pound dragster and a 630HP SBC and I was running upper 8 teens to 20s on methanol but that was 15 years ago. Hope this helps.
R&S Motorsports is offline   Reply With Quote
Old 12-11-2008, 09:24 AM   #3
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
Default Re: 8.90 hp
S&W 235" 4-link 880 H.P. 1915 with me in it. Best time was an 7.50. Average was 7.55-7.57 You can work backwards from there. I am guessing 725-750 should do it.
H.A.A.C. Racing is offline   Reply With Quote
Old 12-11-2008, 09:28 AM   #4
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
Default Re: 8.90 hp
Back when S/C was just starting out, a friend of mine had a lil 331 Aluminum headed motor in his 1650# dragster and would run 8.8's all day long. We figured it to be somewhere around 575-600hp.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 12-11-2008, 10:55 AM   #5
B CHILLIK
B CHILLIK's Avatar
Default Re: 8.90 hp
ive got a small block dragster weighs 1800 and it runs 8.70 all day,its only a 357cu motor roughly about 650 hp....
B CHILLIK is offline   Reply With Quote
Old 12-12-2008, 01:21 AM   #6
R&S Motorsports
Default Re: 8.90 hp
My uncle also has a name brand 4-link car with a roughly 675-725 HP 421 SBC and he runs 8.0's to high 7.90's depending on air. I was probley a little conservitive on my intial numbers I would assume just over 600 would get it done but 2000 pounds is pretty heavy for a dragster unless you are considering driver weight into that number.
Old 01-27-2009, 12:15 PM   #7
Freddie
Freddie's Avatar
Default Re: 8.90 hp
R&S: just curious, why would you not figure the drivers wieght in as well when determining how much power is needed to reach a certain E.T? Almost every class I have ever run car weight is calculated with driver. Just makes the total package wiegh less with a skinny driver ( unlike me )
